basement - moving toilet drain and adding shower
Discussion in 'Shower & Bathtub Forum & Blog' started by moveright, Dec 1, 2009.
  1. moveright
    moveright New Member
    Dec 1, 2009
    maryland
    New here, seems to be a wealth of info, so let's try this for a question. If this works out, I've got about a bazillion other ones:D.
    My basement has a powder room which I would like to convert to a full bath. The floor is concrete as the basement is below ground. The room is very small so I will be needing to move the toilet and sink in order to add a small shower stall. Many years ago, I worked as a plumbers apprentice so I am quite familiar with moving pipes, working with copper/pvc, etc...
    My question is, does a shower have a gooseneck in the drain? Also, I would obviously have to take a demo hammer to the floor and bust up the entire concrete powder room floor in order to move the toilet drain so is there any advice as to how I should plumb this stuff together or any general pointers at all?
    thanks in advance.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    All plumbing fixtures have traps.
    All plumbing fixtures need to be vented in a manner acceptable to your local authority having jurisdiction.
    No one can advise you how to replumb your bathroom without knowing what is there.
  4. jadnashua
    Also, the shower drain needs to be 2" or larger all the way to a similar or larger drain pipe.
    Look into Kerdi from www.schluter.com if you are going to tile the shower. Then, check out www.johnbridge.com for help.
Similar Threads: basement moving
Shower & Bathtub Forum & Blog Moving Basement Shower Drain Jul 11, 2009
Shower & Bathtub Forum & Blog Removing basement shower drain Aug 28, 2006
Shower & Bathtub Forum & Blog Shower Leak to basement... Feb 10, 2017
Shower & Bathtub Forum & Blog Leak In showing on basement wall Aug 12, 2016
Shower & Bathtub Forum & Blog Bathtub install on basement slab - plastic below and on top of mortar? Jul 17, 2016
