Basement Floor Vent (oops)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by seaneys, Dec 30, 2007.
  1. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Note to self...
    When fill checking the dwv plumbing, don't forget to plug the vent line between ejector pit and the basement floor drain..
    I needed to mop the floor anyway...
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Had the pit been used yet?
  4. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Umm.. No..
    Clean as a whistle..
    Steve
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Thats good!
  6. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    Are you saying that the basement floor drain vent and the ejector vent are the same? You wouldn't get away with that here - the sump is supposed to be vented separately if you don't want the pump to siphon traps.
  7. Redwood
    Dec 15, 2007
    Service Plumber
    I think he was saying he was filling the DWV system for a leak test and he didn't block the vent for the pit... When the pit filled and the pump went on it got ugly fast!
  8. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    They are two separate vents, but I join them in the wall on the way to the roof.
    The inspector has not seen this yet.. Did I goof? I could not fund much specific info on vents for ejector pumps. I just made sure the vent and the ejector pump outlet were the same size (2") to be conservative.
    Steve
  9. hj
    vent
    There is no way the pump could siphon the traps even if the tank and fixture vents are connected together, and that is the way we have done it since the beginning of time.
Similar Threads: Basement Floor
Plumbing Forum, Professional & DIY Advice Basement above floor Bathroom Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Closing off Basement floor drain Sep 27, 2016
Plumbing Forum, Professional & DIY Advice Check valve needed? Water on floor of basement. Sep 20, 2016
Plumbing Forum, Professional & DIY Advice Emergency Floor Drain In Basement May 3, 2016
Plumbing Forum, Professional & DIY Advice HELP! Mystery under basement floor... Aug 4, 2015
