Basement Bathroom Reno
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dlarrivee, Jun 28, 2009.
  1. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    I'm planning a renovation of an existing basement bathroom, it currently has a small sink on a vanity, and a toilet. I would like to add a bath tub to the bathroom, and will need to rework the existing drain and vent system.
    The image below shows how I'd like to orient things, so I will be moving the sink and toilet away from the wall that separates the utility room and bathroom, to make room for the bathtub.
    Each dark pink dot, shows where I would like to run a vertical vent for the sink, toilet, and bath tub. Then I will combine them and tie them into the existing vent, for the ejector pump (my sewer line is 1 foot from the slab grade).
    Does this seem kosher? Or would there be a better way to route the vents and/or drain? The ejector pump pit is existing, and most likely has a 3" line running to it left-to-right in the image, straight to where the toilet shows up in the picture. I haven't jack hammered out the concrete yet.
    [​IMG]
  2. dlarrivee
    Jun 28, 2009
    Canada
    Oh, and just to clarify, where the tub meets the main drain, I'd be using a wye with a 45* elbow on it, not a T.
  4. hj
    Y
    If your dimensions are anywhere near accurate, you will be using a "Y" heading towards the "P" trap with the vent combo where it passes under the wall.
  5. dlarrivee
    Jun 28, 2009
    Canada
    [​IMG]
    More like this for the drain away from the sink, I don't know why I tried to draw that with it tying into the closet bend... :rolleyes:
    Does this look alright? I need to add a floor drain as well, there isn't one currently, I would like to put it where the yellow dot is...
    Does the floor drain need a vent as well, I know it needs a trap?
    Can I connect vents together with Ts on their sides? Or should I make it so that there is only wyes?
Similar Threads: Basement Bathroom
Plumbing Forum, Professional & DIY Advice New basement bathroom Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Basement Bathroom Plumbing Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Basement above floor Bathroom Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Help with basement bathroom plumbing design Nov 16, 2016
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
