Basement Bathroom Plans....
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ssgregory97, Jan 18, 2009.
  1. ssgregory97
    ssgregory97 New Member
    Jan 18, 2009
    I am in the process of planning a layout for my unfinished basement.
    1. I labeled the drains to what I believe is correct. Are they?:confused:
    2. Can I raise a tub to drain into the drain on the bottom of the pipe shown in the picture?:confused:
    I really appreciate any input of help I can get in the design of this project.
    Thank you!
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I think you will find that the tub drain is already there somewhere under the concrete. Hopefully there is only a skim over the top ot the box.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Putting a tub on a platform is a real hack job. One thing I wonder about is whether this was roughed in for a tub or a shower. That would make a difference where the drain is. Once you determine tub or shower, then the drain should not be too difficult to locate. (Anyway, that's the theory) Any chance you can locate the blue prints?
  5. ssgregory97
    Jan 18, 2009
    Can I use the bottom opening on the pipe that the sink drain is on to tie in the tub drain? I can't seem to find blueprints so I am not sure where there would be any drain under the concrete. Is it ok to use that line or will it cause issues?:confused:
  6. Gary Swart
    Sep 1, 2004
    Yakima WA
    No, that won't work unless you put the tub on a high platform. You must have a P trap under the tub which mean if the tub is on the floor as it should be, the trap has to be under the floor level. You may have to cut into the floor to find the roughed-in drain.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Take a hammer and do a "tap - tap test." Hopefully You find an area that sounds different from the rest of the floor. This should be a skim covered box where your tub or, shower drain is. Bash it up and find your drain....
  8. hj
    drain
    That opening is NOT a drain opening, it is a cleanout to access the pipe if, and when, it plugs up. Given the orientation of the tee above it, I doubt that the tub was intended to go where you anticipate it. It is probably on the other side, to the right of the toilet using your pictures.
Similar Threads: Basement Bathroom
Plumbing Forum, Professional & DIY Advice New basement bathroom Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Basement Bathroom Plumbing Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Basement above floor Bathroom Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Help with basement bathroom plumbing design Nov 16, 2016
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
