Basement Bathroom addition
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Adam Roseneck, Feb 19, 2013.
  1. Adam Roseneck
    Adam Roseneck Weekend Warrior
    Feb 19, 2013
    Automotive Service
    Ottawa, Ontario, Canada
    I've been reading through the forums and picked up some invaluable information but was hoping for some specific information. I've attached a copy of my proposed layout. The ejector pump is required because my main drain exits the basement wall about 3 " from the floor. There will also be a sink to the left of the toilet and a kitchen sink just south of this entire diagram. Both of these appliances will share a vent with all the kitchen fixtures but will drain into the main.
    I have a few questions about making a vent. All the other fixtures in the house are on the main level (none on the second level). Assuming that there is no vent dedicated to the basement, will I have to run a line up to the attic (or at minimum 6" above the flood line of all upstairs fixtures)? Is there any way to vent into any other lines? I've attached some photos of the existing plumbing work.
    Lastly, am I correct to assume that I need either a combo or a wye and a 1/8 on its back to shoot the 2" vertical vents in my diagram? sanitee will not work? drain layout.jpg
    Thanks for any help that can be offered!
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The sewage basin and the fixtures traps must be vented, either on a dedicated vent or tied in 42" above the main floor. You cannot tie into a vent below the flood rim of any of the fixtures it serves.
    A sanitary tee is for transitioning a horizontal drain to a vertical drain, it should never be installed laying on it's back.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I would keep the 3" line straight from the water closet into the basin. The sink drain will be in the wall with a 1-1/2" vent going up and a 2" drain going to a wye into the main line. This vents the water closet through the sink's vent so that the WC will not need it's own vent. Tie the shower in with another wye closer to the basin. The shower's drain should be 2" but it's vent going up into the wall only need be 1-1/2".
Similar Threads: Basement Bathroom
Plumbing Forum, Professional & DIY Advice New basement bathroom Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Basement Bathroom Plumbing Jan 19, 2017
Plumbing Forum, Professional & DIY Advice Basement above floor Bathroom Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Help with basement bathroom plumbing design Nov 16, 2016
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
