Ball valve replacement.
Discussion in 'Irrigation / Sprinkler Forum' started by matty, May 18, 2009.
  1. matty
    matty New Member
    May 18, 2009
    Let's start by saying I am quite the plumbing novice. I have a cracked Ball valve on my sprinkler system that needs to be removed and replaced. I have tried to torch the valve and break the soldered connection to no avail, Suggestions?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    You would want to cut the plastic pipe to make sure there is not even one drop of water inside the valve you are trying to head.
    Bigger torch, FD standing by;
  4. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Where is your backflow preventer? You ain't legal without one of those, and your home is unsaleable with major code violations.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I suggest you contact a lawn sprinkler installation company. There are at least 3 problems I see. First, the valve is not a frost free, second, there is no backflow preventor, and third, you absolutely can not heat a joint enough to melt solder if there is any, repeat ANY water even close. You are risking your family's health with this hacked hook up.
  6. matty
    matty New Member
    May 18, 2009
    Valve replaced, back flow protector installed, thanks for the advice.
  7. hj
    Good, now show us a picture of what you used and how you did it.
Similar Threads: Ball valve
Irrigation / Sprinkler Forum Freeze Tolerant ball valves Feb 18, 2014
Irrigation / Sprinkler Forum Freezing PVC ball valves Aug 13, 2008
Irrigation / Sprinkler Forum How to know which zone on valve goes to which sprinklers Feb 19, 2017
Irrigation / Sprinkler Forum Valve Box Too Low - Should I Stack Boxes? Jan 31, 2017
Irrigation / Sprinkler Forum Valve, station question Aug 16, 2016
