baffle is loose in a 1000' gallon septic tank?
Discussion in 'Toilet Forum discussions' started by panahead, Jun 22, 2009.
  1. panahead
    panahead New Member
    May 2, 2009
    i have just had my 1000' gallon fiberglass septic tank (of 20 years) pumped and the guy who pumped it pointed out that the the baffle that seprates the tank into 2 separate chambers is coming loose from the side walls of the tank? the seal on the side of the baffle is leaking.... also there is only one opening in the baffle? a 3" hole near the top of the baffle... he recommended that i drill 3 additional 3" holes near the bottom of the baffle and he also said that i should repair the baffle... is this something that i should do? should i crawl in there and patch in with a fiberglass repair kit? with a good fan to clear the fumes... or should i leave the tanks with just the one whole between the chambers? the first chamber was about 1/2 filled with sludge and the 2nd had much less sludge in it... any advice is appreciated
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I know a go to kinda guy I would like to recommend for this job. I think he's back from holiday. :cool:
Similar Threads: baffle loose
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Feb 15, 2017
Toilet Forum discussions Baffled By A Toilet Ghost!!! Sep 9, 2012
Toilet Forum discussions Baffled - Toilet in new construction leaks Oct 26, 2007
Toilet Forum discussions 'Loose' Toto SS204 Seat; Normal, or Not? Sep 15, 2015
Toilet Forum discussions Is my new Toto SS114 toilet seat supposed to be loose and floppy? -with video- Feb 18, 2013
