Backflow output
Discussion in 'Irrigation / Sprinkler Forum' started by Nereus, Oct 31, 2006.
  1. Nereus
    Nereus New Member
    Aug 11, 2006
    Retired but help my son in his lawn care business.
    Joplin Missouri
    Need some help here.....last fall a contractor winterized one of our systems by removing the backflow and blowing out the system, but last spring the backflow he reinstalled was not the one he took away. He took away a 1 1/2 inch and put back a 1 inch. He had to install reducing unions to make the connection. When I asked about it he told me it was a 1 1/4 inch backflow, not a 1 1/2 inch and that a 1 inch will put out the same volume and pressure as a 1 1/4 inch backflow. My question is, wouldn't a 1 1/4 inch backflow require 1 1/4 inch pipe and fittings? These lines are 1 1/2 inch. And, does a 1 inch backflow put out the same volume and pressure as a 1 1/4 inch backflow?
    I believe we were flim flammed.
    Nereus:confused:
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The pressure will be the same regardless of the size. The volume will be less with the smaller backflow, but you'll still have plenty of water. My system has 1" from the meter with a 1" backflow into a 1-1/2" line to the valve manifold. Perhaps I don't understand your situtation. Do you own the backflow? If so, it seems to me the same BF should be reinstalled even though what was put in does work OK.
  4. Cass
    Cass Plumber
    Nov 12, 2005
    I would just call them back and have them put in the same size that was taken out.
  5. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Did he charge extra for the work involved in changing the pipe configuration? The lawn irrigation companies I install RPZ's for remove the RPZ and give it to the customer to store until spring time. There is no valid reason for what he did.
Similar Threads: Backflow output
Irrigation / Sprinkler Forum Leaking Watts Backflow Preventer Oct 12, 2015
Irrigation / Sprinkler Forum Pressure vacuum breaker backflow prevent or always engaging May 21, 2015
Irrigation / Sprinkler Forum Not getting water through backflow preventer May 17, 2015
Irrigation / Sprinkler Forum Backflow device for greywater changeover device Apr 29, 2015
Irrigation / Sprinkler Forum What type of backflow device is this? Apr 4, 2015
