Back to back commode flushing problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cvonkantor, Mar 12, 2007.
  1. cvonkantor
    cvonkantor New Member
    Mar 12, 2007
    We hope you can help us with this problem.
    Our house was built in 1988. Our master bedroom commode backs up to the commode in the half bath.
    We replaced our Kohler commode in the master bedroom with an American Standard Champion. Now, whenever you flush the AS commode it causes the Kohler commode to flush / drain in our half bath.
    We have had the lines checked and the air vent...all are clear.
    Our plumber suggested we move the AS commode to the guest bath, which stands alone and doesn't back up to another commode, and install a Toto Drake model in the master bathroom.
    Then he called today to say he couldn't guarantee the same thing wouldn't happen even with the Drake model.
    Do you have any suggestions regarding this problem?
  2. hj
    toilets
    Now, whenever you flush the AS commode it causes the Kohler commode in our half bath.
    You didn't finish the sentence. It causes it to do what? Whatever happens it almost has to be a poor piping installation, not a toilet problem, per se, but a strong flushing toilet combined with an improper pipe installation could cause problems between the two toilets. And if so, ANY toilet could cause the same type of problem.
  4. cvonkantor
    Mar 12, 2007
    It never happened before we installed the new AS Champion commode. Is there a good commode that doesn't have the strong flush that we can install to alleviate this problem?
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    It's a drain/vent problem, not a toilet problem..........
Similar Threads: commode flushing
Plumbing Forum, Professional & DIY Advice My septic tanks inlet is lower than my commode drain Sep 2, 2008
Plumbing Forum, Professional & DIY Advice Gurgling in drains after flushing Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Back flushing water lines in a home filled with dirt, silt and gravel Oct 5, 2016
Plumbing Forum, Professional & DIY Advice Toilet not properly flushing.. May 23, 2016
Plumbing Forum, Professional & DIY Advice Flushing Toilet, Coming Through Shower Drain... Only When A Lot Of Water Is Used Apr 25, 2016
