Autotrol 255 Problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jslear, Dec 22, 2006.
  1. jslear
    jslear New Member
    Dec 22, 2006
    I have a three-year old Autotrol 255 with a 440 timer. It was working fine until a week ago. Now, when the regeneration process runs, it sounds like it's running through the process okay, but it doesn't draw any brine AND it also doesn't send any water to the brine tank during the fast rinse/refill step. Following the manual, I've replaced the check valve (there was no ball in the original one!), I've cleaned the injector and injector screen. Is there one failed item that can cause both of these symptoms? Any advice would be appreciated... Thanks!
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    air leak
    usually if the unit wont draw brine the first thing to
    check is wether their is a leak in the suction line...
    usually it will fill the brine tank too full over a ffew cycles
  4. Gary Slusser
    Retired
    Make sure it is plugged into a working 120v receptacle and keeps time and rotates the flapper valve cam shaft during a manual regeneration.
    Remove the injector and make sure you can see light through it length wise and that is not partially blocked.
    Remove the salt dose control and make sure it is not blocked. Remove the injector and the injector screen and run a small brush through the injector/screen passage way; in the injector hole out the screen hole on the other side of the control.
  5. jslear
    jslear New Member
    Dec 22, 2006
    Thanks for the suggestions on the Autotrol 255 problem. It DID turn out to be related to the suction line from the brine tank - it had a clog in the bottom of the feed line. Thanks again... - js
Similar Threads: Autotrol Problem
Plumbing Forum, Professional & DIY Advice Closet flange problem! Monday at 10:05 AM
Plumbing Forum, Professional & DIY Advice Our seemingly never ending sewer line under the house problem Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Perfect Grind Garbage disposal problem Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Well problems Jan 26, 2017
