automatic pump
aaaaaa
philadelphia
I am hoping to drain water from a collection tank once a day, i am just curious what sort of valve, timer, setup would be recommended here.
Thanks
A "manual pump" with an auxiliary float switch to prevent it from overfilling would be the first thing, then a timer in parallel to the float switch, so either one turns the pump on should give you what you want.
