Attaching new wall to existing house
Discussion in 'Remodel Forum & Blog' started by seaweed1, May 6, 2006.
  1. seaweed1
    seaweed1 New Member
    May 6, 2006
    Hello: I am planning to enclose a north-facing entrance within the side walls of a garage I wish to build. My house has cedar shingles as siding and I intend to cut the shingles down to the sheathing along a stud to prepare an area to attach the cornerpost of the wall to the house.
    The question I have is: how do I flash this vertical cut (approx. 8 feet) - do I simply run continuous flashing down the side of the corner post or is there another method of protecting the cut area from water infiltration? Thanks.
  2. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    This is what I would do: I would remove few cedar shingles from each course along the outside-side of the cut and place some ice and water barrier in the corner. Maybe 12in along each side. That's the same stuff used for roofing and windows/doors, etc. Then put your corner board in place (square cross section of size slightly larger than depth of your shingles) and butt them up to it. Make sure when you replace the shingles you don't have any joints lined up. Any water that infiltrates the corner will find its way down via the water and ice barrier.
    Make sure whatever you do at the bottom near the foundation doesn't allow water to get in around the sill.
    When you replace your shingles, make sure you match the spacing of the old. As they get older and dry out/shrink they leave a little gap. If you butt the new (or reused old) ones up tightly it'll be obvious that its a repair even after they weather.
    Jason
  4. seaweed1
    seaweed1 New Member
    May 6, 2006
    Thank you for taking the time to respond Jason.
    I shall follow your well-thought out information and I feel it will do the job.
    Regards,
    Dave
Similar Threads: Attaching wall
Remodel Forum & Blog Attaching to a concrete block wall Jul 12, 2016
Remodel Forum & Blog attaching wood railing and posts to tiled concrete Apr 14, 2011
Remodel Forum & Blog Attaching 4x4 posts to concrete Nov 12, 2007
Remodel Forum & Blog attaching stud Aug 10, 2007
Remodel Forum & Blog Boring Holes in Non Load Bearing Wall Oct 6, 2016
