asthma inhaler flushed and is blocking toilet -
accurare
Denver, CO
Hi everyone, I have a clogged toilet due to a simultaneous flush and my asthma inhaler falling out of my pocket into the toilet bowl. Plunger was ineffective, so I have oredered a Ridgid k-6 toilet auger. Has anyone specifically flushed one of these or similar item? Wondering if it was successfully pushed through or pulled out using an auger. For those who have not experienced this, what is your guess as to my chances of removing it or pushing it through into the mainline with an auger? I'll find out soon, but anxious to hear anyone else's success story. Thanks.
The normal thing to do is to lift the toilet off, clear the path, and put the toilet back into place with a new seal. Wax is the classic seal, but waxless has some advantages.
If you had a plunger nearby because you sometimes need it with that toilet, you might take the opportunity to put in a better toilet while you are at it.
accurare
Denver, CO
Thanks, I appreciate your reply, but I don't have the skill to reseat a toilet, which, if it is necessary, I will hire a plumber to do it, and specifically, since I will be getting an auger delivered tomorrow, I was curious about that specific method. Anecdotally, I did read a message from someone that flushed her asthma inhaler down the toilet without any blockage (in 2010), so depending, I suppose on some variables, such as diameter of the inside plumbing passages of the toilet, and ability to accidentally reposition the object in such an angle as to ease the passage, etc, and I thought perhaps there might be others who have shared that particular misfortune with a good outcome, using an auger.
