Aquastat setting
Discussion in 'HVAC Heating & Cooling' started by JJLJr, Nov 6, 2007.
  1. JJLJr
    JJLJr New Member
    Oct 29, 2007
    Rhode Island
    I recently purchased a 1200 sq ft. ranch style house with an old Crane 70 Series oil fired boiler. I'm probably going to replace it down the road. In the meantime, I want to get it running as efficiently as possible. I did have an oil company clean the boiler and the tech said that it was running well for an older boiler.
    My question concerns the aquastat setting. The aquastat is a Honeywell 8124. The settings are hi 180, lo 160, and differential 20. The boiler originally had a tankless coil for heating hot water; however, now there is a separately gas fired hot water tank.
    The system seems to occasionally (every 15-30 minutes) come on for a minute or two and then shut off. It also seems to take a long time for the system to come to temp. I know the aquastats can vary over time. I can't confirm the hi temp as the boiler temp guage doesn't seem to working.
    I have a few questions:
    1) Since the boiler no longer is supplying hot water, can the low setting be reduced;
    2) Should I raise the hi setting so that the system can run a little higher which should reduce cycling and heat up time.
    3) Since the temp guage doesn't seem to be working, should I attempt to take the water temp from the water in the pipes. I know it it gets colder as it goes through the system but at least I can get tell if it is any where near the hi temp.
    Thanks for your help.
Similar Threads: Aquastat setting
HVAC Heating & Cooling Proper Aquastat Settings Nov 8, 2007
HVAC Heating & Cooling problem with aquastat setting for coil Mar 9, 2007
HVAC Heating & Cooling Aquastat wiring question Oct 20, 2015
HVAC Heating & Cooling Adding Zone valves to Honeywell Aquastat L8148J Mar 6, 2014
HVAC Heating & Cooling Boiler Temp 240F - Bad Aquastat? Feb 10, 2011
