AquaPex and the ferrous issue isolation
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by HoracioO, Oct 10, 2009.
  1. HoracioO
    HoracioO New Member
    May 10, 2009
    NV
    I'm researching the phased replacement of my hot and cold water supply lines. Currently they 50 year old galvanized pipe, and so I'm going to have to transition to PEX at the outlets (bathrrom) and work backwards over time. Reading about AquaPex is states quite clearly:
    I read this as applying only to hydronic heating applications. Correct?
    Are there any other issues I should consider before I under take this task? I'd really like to replace in one go, but this is just not possible at this time and there seems to be some easy joins that I can use to get started so I won't need to cut into the pipe...
    Cheers
  2. HoracioO
    HoracioO New Member
    May 10, 2009
    NV
    Answering my own question... clearly it is for hydronic heating, as the tubing does not have an oxygen barrier and ferrous material in a recirculating (closed) system will oxidize...
    Oxygen is already in water so for retrofits this is not an issue, but it is the very reason why we replace the galvanized/iron pipes.
Similar Threads: AquaPex ferrous
Plumbing Forum, Professional & DIY Advice Aquapex vs PEX-A Aug 25, 2015
Plumbing Forum, Professional & DIY Advice Aquapex with crimps? What's current? Aug 28, 2014
Plumbing Forum, Professional & DIY Advice Uponor AquaPEX size 1/2 vs 3/4 Nov 15, 2013
Plumbing Forum, Professional & DIY Advice Using aquapex instead of hePex May 14, 2013
Plumbing Forum, Professional & DIY Advice Uponor Aquapex Tubing and Ultraviolet Light Sep 18, 2012
