Anyway to clean iron from inside of softener/resin?
Discussion in 'Water Softener Forum, Questions and Answers' started by JoshB-NC, Oct 25, 2012.
  1. JoshB-NC
    JoshB-NC New Member
    Sep 20, 2012
    North Carolina
    Was having a problem with sulfur smell and had slightly hard water. Bought a new Filox system (another thread in this forum) as suggested on here. Also bought a used Culligen silver series softner. Filox seems to be working great, sulfur smell is gone. We do now have a metal smell. I am assuming it is coming from the water softener. When I was installing - I pulled the head off the water softener tank and noticed rust staining inside. Also the previous owner had the clack drip feed hooked up inside brine tank. The resin seems to be working as the water is noticeably softer (ordered a hatch test kit and waiting for it to come in..). Is there anything to clean out the rust (I am assuming it is from iron)? We do not have a iron problem here - it was just 11 grain hard water and the rotten egg odor. And I am thinking the metal smell is from the softener???
  2. Gary Slusser
    Retired
    Since you have the control valve off, lean the resin tan over and pour out all the water you can get out without resin. Then mix a 1/2-3/4 cup of Iron Out/Super Iron Out in enough water to dissolve all of it and pour that in the resin tank and fill the tank with fresh water. Install the control valve. Let it sit for a few hours and then add 2 gallons of water to the salt tank, not down through the salt, wait 2 hours and do a manual regeneration.
    The only other way is to empty the tank and let it dry out inside and then use a brush on a stick to scrape the rust off the inside of the tank. Do not let the resin dry out, keep it covered with water at all times.
Similar Threads: Anyway clean
Water Softener Forum, Questions and Answers Resin Cleaner? Jan 19, 2017
Water Softener Forum, Questions and Answers Water Softener resin cleaning ? Oct 30, 2016
Water Softener Forum, Questions and Answers How to clean the contact tank / precipitate tank Aug 20, 2016
Water Softener Forum, Questions and Answers Kinetico 2060 iron filter cleaning - gear alignment??? Feb 29, 2016
Water Softener Forum, Questions and Answers Water softener cleaner Feb 11, 2016
