Anyone know if there are new ARC FAULT requirements in NEC 2008?
Discussion in 'Electrical Forum discussion & Blog' started by lahabra, Dec 24, 2007.
  1. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    I herd that arc fault requirements are going to be expanded soon.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    For more information go here
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    That depends.
    Will your area adopt the 2008 NEC?
    If so when?
    If so then go to JW's link and read up.
  5. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    Also, some AHJs are adopting the '08 and are modifying it so AFCIs are not required.
  6. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    The 2008 code requires AFCI protection for ALL new 120 Volt circuits in residences. You should pull your permit before the 2008 applies in your jurisdiction to avoid that expensive stupidity.
    Existing circuits usually don't fall under the new code.
  7. 480sparky
    Oct 8, 2007
    Not quite. Only 15- and 20-amp circuits, and only those suppyling "family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreational rooms, closets, hallways, or similar rooms or areas..."
    Note that garages, laundry rooms, kitchens, baths, basements, crawlspaces, and exterior outlets are missing from that list.
    2008 NEC 210.12(B).
  8. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    Smoke detectors,
    Since hard wired smoke detectors and lights are in bedrooms, will they also need ARC fault protection?
  9. lahabra
    lahabra New Member
    Dec 21, 2007
    California
    I already have my permit. I am under the impression that my job must be in compliance with current codes on the date it is inspected, regardless of when the permit was issued.
  10. 480sparky
    Oct 8, 2007
    Yes, smoke detectors fall within the NEC definition of an outlet.
  11. Speedy Petey
    Jun 16, 2007
    NY State, USA
    How could that possibly be?
    What if you get a rough-in on 12/27/07 and a finish inspection on 1/27/08? Are you suggesting they would use the '08 code for the final???
  12. 480sparky
    Oct 8, 2007
    When (if they do) are they going to adopt the '08 in your area?.... that's the critical point you need to find out. Many places don't adopt the '08 automatically on Jan. 1, 2008. Some places may take two or three years to begin enforcing it.
Similar Threads: Anyone FAULT
Electrical Forum discussion & Blog Does ANYONE make a switch with MULTIPLE DIMMERS in 1 gang, for LEDs and 3 ways in decora/rocker?? Nov 8, 2015
Electrical Forum discussion & Blog Anyone an electrician or know a good electrical forum? Apr 1, 2009
Electrical Forum discussion & Blog Has anyone used or heard of the powershaver? Feb 17, 2009
Electrical Forum discussion & Blog Making a safer circuit i am told anyone of these do Apr 9, 2008
Electrical Forum discussion & Blog I want to know about adjustable speed machine (ASM). Can anyone help me, plz? Oct 29, 2007
