Anyone familiar with Weathermatic valves?
Discussion in 'Irrigation / Sprinkler Forum' started by amartin725, Jul 18, 2005.
  1. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    By the time it gets sorted out, it might be 2015. Sad, really. amartin's modification is interesting, to lower the operating voltage of the valves. (some diodes wired in series could have done it more simply) Lower voltage would reduce the buildup of heat, which may have been a contributor to the solenoid issues.
  2. amartin725
    amartin725 New Member
    Jun 27, 2005
    Well, it does go a little bit farther. The controllers are intelligent and monitor current through the solenoid. Variances in voltages lead to variances in current sensed and it trips the controller showing Err on the zone. I compensated for this, but I can't give away all of my secrets ;)
  3. Wet_Boots
    Mar 23, 2007
    Metro NYC
    What controller are you using?
  4. amartin725
    Jun 27, 2005
    Hunter Pro C.
  5. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
    Replaced another failed solenoid off of the same system I have had 2 other previous failures on. Looks like water got wicked into the body somehow, rust was seeping from where the wires meet the body. This was on a Weathermatic Silver Bullet valve, and had square solenoids. No failures so far on the same system with the round replacement solenoids.
    This was a system installed 3 years ago.
  6. Overheatprotection
    Overheatprotection New Member
    Oct 6, 2007
    discount sprinkler service.com And- overheat prote
    port richey,fl.
    i have been using irritrol valves they seem to be the longest lasting valves on the market. and its the only valve I install. I give an unconditional replacement guarantee. Out of about 1000 I have installed I only had to warranty about 8 of them. that valve seems to last about 15 years,
    I have been in business over 25 years and the only products I use are the ones that last the test of time. When I cut this style of valves out of the sprinkler system I have pulled some out that were over 20 years old when they finally broke. And yes irritrol has not produced this valve for 20 years but the style has been around I think for about 26 years under different names the original company has been bought out several times by different companies and improvements have been made to it. Even Rainbird solenoids seem to last only about 8 years or so.
    Never cheep out on valves because you don't want to do the job twice.
  7. miner49er
    miner49er New Member
    Oct 18, 2007
    i use toro, rainbird valves. toro/k-rain heads. no problems to this date.
    miner49er
  8. PJ Flocker
    PJ Flocker New Member
    Oct 27, 2007
    Phoenix, AZ
    WM Solenoids
    Well...I have to say, this is the longest post I have seen on one subject!! I just joined this forum to enter my comments. I was just surfing the web to find a place in PHX, AZ for replacement solenoids for the WM valves and I ran into Terry's forum here. Thank you Terry for creating this!! I have had my system for a little over 3 years and it has been fine until recently. I have three WM valves and an Irritrol controller..this has not been an issue. I just want to replace two solenoids for now and see if I have any further issues before I decide to replace the valves. It looks like I have a 1" Silver Bullet 12000 w/flow controller. I have not been able to find replacement solenoids in the Phoenix, AZ area or on line. Anybody have any recommendations please??:cool:
    PJ
  9. Wet_Boots
    Mar 23, 2007
    Metro NYC
    The valves should be fine, if they've been working so far. As for solenoids, I've seen old W*M brass valves with Irritrol solenoids, so maybe that can work on your plastic valves, if you can't locate W*M replacements, although, around a big city like Phoenix, there should be a source for W*M.
  10. Irrigation Oldtimer
    Irrigation Oldtimer New Member
    Dec 5, 2007
    Weathermatic M24E Solenoids
    Weathermatic experienced a problem with the M24E solenoid relating to water penetration. They have replaced the M24E with the S20P solenoid. All of the reports I have heard on this solenoid are excellent. I recommend that you contact the company's tech service department if you are still having problems. Have you tried the Weathermatic SmartLine controller? This is a really cool product. It adjusts watering times based on the weather. They have a site about the product called www.smartline.com. A lot of water providers are giving rebates for installing a product of this type. Many of these rebates are listed on the Smartline site.
  11. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Well, I ran into a system that had an 06 date on the failed W*M solenoid. Replaced every one of them from my stock of 20th-century M24Es - I wonder if W*M will ever tell the entire truth about this debacle, or whether they even understand all that transpired.
  12. jimbo
    jimbo Plumber
    San Diego, CA
    Well, we are 6 days away from the 3rd year anniversary of this thread. Going for 4!
  13. Wet_Boots
    Mar 23, 2007
    Metro NYC
    W*M bailed on the M24E. At least they were aware enough to know how thoroughly they poisoned the market with their incompetence. The new solenoid is named S20P.
  14. peejmeister
    peejmeister New Member
    Jun 28, 2006
    dallas, tx
    Still Losing Solenoids Left and Right
    Can't let this thread die now!
    When I turned my 32-valve system on early this summer, as I expected, I started losing solenoids again.
    I contacted Weathermatic and they touted their new S20P solenoids and sent me a box of 32 of them, no charge. I've been putting them in as the old M24Es die. I've only had the S20Ps out there for a few weeks, but none of them have failed yet.
    :confused: My biggest problem now--assuming these S20Ps really last--is replacing the solenoids without cross-threading them. You do that once and you have to replace the valve cover to get another solenoid to stay in.
    Now that the new S20P is narrow enough to access the screws on either side of it, I may resort to pulling the cover, installing the new solenoid in plain site, outside of the valve box, then screwing the cover with the solenoid on as one unit, unless anyone has a more sure-fire way to get them in snug enough to operate without making that fateful last twist that ruins the valve.
  15. Heater63
    Heater63 New Member
    Jul 26, 2008
    Texas
    first M24 failure
    Well, after discovering this thread, I'm not going to let it die either! I have a small Weathermatic system, in place for 12 years now, and I just had my first M24 failure; it is dated 1996 and the side case is finally cracking from heat cycles. I have not had a valve failure yet. I have a WM controller, and although I kinda hate it, I have learned to use it. The LCD did go bad after the warranty period, and when I contacted WM, they sent out a whole new controller, they were very very good; this was about 2000. my 2 cents on WM. Kudos to aamartin for not going postal at some point and figuring out a voltage patch.
  16. TGreenway
    TGreenway New Member
    Sep 26, 2006
    Charlotte NC
    Last post was May, 2007...it's now Sept 2008, and I haven't had a single failure since my installer replaced the WM valves with Hunter valves....I guess if the valves continue to work as long as this thread, then I'll be happy.
  17. GeekZero
    GeekZero New Member
    Jun 20, 2009
    Now it's 2009
    Thanks all for the information here; our builder put in Silver Bullets in the summer of 2004, and since then we have replaced a lot of solenoids. I just put in the first S20P, let's hope that is the real "silver bullet"
  18. jimbo
    jimbo Plumber
    San Diego, CA
    Well, we are now just a few days short of the 4th anniversary on the post that won't go away!!
    Not as many posts as the whirlpool water heater, but excellent staying power!
  19. Kuhlman5
    Kuhlman5 New Member
    Jul 6, 2009
    S20P Failed After One Irrigation Season
    I was out testing my nine zone irrigation system over the weekend here in New Jersey where we had 20+ days of rain in June. The system was not responding to controller commands 100% of the time. This morning the controller said I had a short in the master valve. After disconnecting the master valve solenoid (the new replacement version S20P) and manually opening the valve (Weatermatic 12000 Series - Silver Bullet) the system work flawlessly. The irrigation system was installed late in 2007 (Oct/Nov.) worked well in 2008 and the master valve solenoid failed at the beginning of 2009.
    Gene Johnson @ Weathermatic offered to sell me a replacement under a special program for $6.30 + 9.90 S&H.
    I can't say I'm impressed.
  20. samson smith
    samson smith Guest
    If you have garden and you want to make it more beautiful then sprinkler is the best option for this purpose. Sprinkler controllers helps you how to control the water system. It also helps to make water system easier and helps to save the water. Sprinkler valves are the most important part of the sprinkler water system. It is helpful to control the water.
Similar Threads: Anyone familiar
Irrigation / Sprinkler Forum Can anyone identify this irrigation valve for me? Dec 7, 2015
Irrigation / Sprinkler Forum Irrigation controller acting funny. Has anyone ever seen this? Sep 7, 2014
Irrigation / Sprinkler Forum Anyone using any ET based sprinkler controllers? Jun 29, 2006
