Anybody object to this pass/fail specification for city water delivery?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Thatguy, Oct 28, 2010.
  1. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Based on [more or less] responses from two water utilities,
    an adequate city water supply for a single family house can deliver
    more than 5 GPM and
    between 20 & 80 PSI and
    PSI x GPM should be more than 400.
    This last line takes about 1/4 hp to accomplish and is my addition to this benchmark.
  2. hj
    And WHAT is the relevence of PSI x GPM being 400? That does NOT create ANY useful measurement. IT is like a toilet's 1.6 gpf x 6 lpf equals approximately 10.
  4. jimbo
    jimbo Plumber
    Why do you need to write a spec for the city? They will deliver what they feel like. Many places, they will deliver much higher than 80 psi, and rely on you to provide a regulator.
    The minimum gpm is based on meter size. A 1/2" or 5/8" meter will deliver 5 gpm. If you want more gpm, you have to PAY for a larger meter. And the city will deliver whatever volume you choose to pay for.
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Sorry for the misleading title.
    It's a spec for OPs to judge if their city water supply is substandard or if a pipe is partially clogged. That question/complaint comes up a lot.
    The static pressure and max flow rate is not hard to get, but the 400 is an approximation to a pump curve between these two endpoints. It corresponds to about a 1/4 to 1/2 hp pump.
    If your house can maintain 40 PSI while delivering 16 GPM you're doing well. 5 GPM @ 5 PSI is terrible.
    Here's what two WaCos said
    Per the Department of Health Waterworks Regulations the
    minimum allowable delivery pressure is 20 psi.
    . . .our targeted range for delivery pressure is 40 to 80 psi. Flow rates are a function
    of demand but a standard size residential meter (5/8") has a maximum
    capacity of about 20 gpm.
    and
    We don't use a benchmark. The pressure range is between 40 and 80lbs. if
    below 40 a booster pump is need and above 80 a pressure reducing valve.
  6. hj
    The usual calculation is gpm AT a specific psi, NOT gpm TIMES psi, (which does not yield any kind of useful number).
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    GPM at a specific PSI or feet of head implies horsepower.
    hp = (head x GPM)/3956 for water.
    If you wanted to simulate city water and you lived next to a lake and your house was a few inches above the lake's surface, a 1/2 hp pump at any depth would probably work.
    I think the WaCos don't use this because almost always just a static pressure and working water meter guarantees a usable water supply. Only when there is a problem do they use instruments and charts.
Similar Threads: Anybody object
Plumbing Forum, Professional & DIY Advice Has anybody seen one? Jul 8, 2014
Plumbing Forum, Professional & DIY Advice Have anybody seen this faucet fastener before? Jan 18, 2014
Plumbing Forum, Professional & DIY Advice did anybody greased EPDM seal of a butterfly valve Oct 27, 2013
Plumbing Forum, Professional & DIY Advice Anybody heard or has Nantucket faucet? Jun 18, 2013
Plumbing Forum, Professional & DIY Advice Anybody do Radon? Sep 16, 2010
