another sewer gas mystery
Discussion in 'Toilet Forum discussions' started by ginahoy, May 18, 2007.
  1. ginahoy
    ginahoy Building Systems Engineer
    Dec 23, 2006
    Sierra Vista, AZ
    In my last house, I experienced an occasional but obvious sewer gas smell from at least two of our three toilets. The third one got little use. I did many things to troubleshoot. The smell was definitely coming from inside the bowl.
    Both offending toilets had overflowed at one time or another, so I figured dirty water had risen above the fill holes and leaked into the upper rim, leaving deposits on surfaces that never get flushed. I finally ended up taking one of the bowls outside for a thorough cleaning. Among other things, I turned it upside down and filled interior of rim with bleach. After carefully reinstalling the toilet with a new ring, the smell eventually returned. Mystery was never solved.
    Shift forward in time. I recently moved into a two-year old house with two toilets. One had a defect and had to be replaced. Since then, I'm certain this one has never overflowed. To my surprise, I've had several instances of a definite sewer gas smell from both toilets. I'm sure it's coming from the bowl because the smell hits you in the face when you open the lid. I'd guess this has happened about four times in as many months. No amount of bowl cleaning eliminates the odor, but the ordor seems to go away as suddenly as it began.
    This makes no sense to me. The inside of the upper rim is the only part of the toilet I can't clean, at least not directly. But since the toilet bowl is new and never experienced an overflow, the rim would only have seen clean water! So where is the odor coming from?! I always thought a toilet trap provides absolute protection from sewer gases.
    Or is this simply an unavoidable fact of life?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    #1 Do you have well water?
  4. HandyAndy
    HandyAndy General Contractor, Farmer
    Apr 17, 2007
    Haxtun, CO
    Is there gurgling or bubbles coming back up at any time or in any of the other fixtures, (could a vent be plugged), bird nest or some thing, or some other type of blockage.
  5. ginahoy
    Dec 23, 2006
    Sierra Vista, AZ
    I haven't noticed this. In any case, if a vent were obstructed, it is my understanding that would interfere with flushing or slow down sink drains. Haven't seen this at all. Also, I've only noticed the odor a few times over a period of several months. Of course, I don't make a habit of sticking my head in the bowl :eek: It may be just a matter of degree...?
    To answer previous poster...
    We're on municipal water (and sewer).
    David
  6. uniberp
    uniberp New Member
    May 18, 2007
    If your municipal water is drawn from wells, as is common, you may still have an issue with water odor.
  7. ginahoy
    Dec 23, 2006
    Sierra Vista, AZ
    Yes, our municipal water comes from wells. It has a very slight odor. However, the only mineral it contains in abundance is calcium.
    The sewer gas smell is unmistakeable. No possiblity I'm smelling the water!
  8. jadnashua
    If the wax seal is compromised, it won't necessarily leak water all over things - it would only leak if there was a clog and the water backed up.
    Do the toilets move at all, even the slightest? If so, then the wax seal could be compromised. It can easily leak gasses and not leak moisture.
  9. ginahoy
    Dec 23, 2006
    Sierra Vista, AZ
    When I replaced the one toilet a few months ago, I was very careful with the ring. I haven't checked the second toilet. Perhaps I should. In any case, they are rigid on the tile floor. Having said that, when the odor has occured, it usually waffs up when I open the seat, as if it were accumulating inside the bowl.
  10. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Just because a toilet doesn't rock, doesn't mean the seal is good. Are the flanges sitting on the finished floor? If not, you have a problem.
Similar Threads: another sewer
Toilet Forum discussions Another toilet install resulting in sewer smell Jan 22, 2008
Toilet Forum discussions Another sewer gas mystery Sep 11, 2006
Toilet Forum discussions Another slow draining/bubbling thread Nov 13, 2016
Toilet Forum discussions Yet another Flange height question for Aquia II Oct 20, 2015
Toilet Forum discussions Yet Another Urine Smell May 2, 2015
