Anode rod - magnesium - right choice ?
Discussion in 'Water Heater Forum, Tanks' started by dikshe, Feb 16, 2009.
  1. dikshe
    dikshe New Member
    Feb 7, 2009
    Originally Posted by dikshe
    I've never replaced the anode rod on my 10 yr old water heater. I replaced the dip tube - that was easy but the anode rod won't budge with a 24" breaker bar applied to it. I'm wondering if too much force could rupture the tank. for 2 weeks I've spayed penetrating oil on the threads but it's still stuck. So 2 questions:
    Can I safely apply heat with a propane touch to the threads ?
    Can I rupture the tank by applying too much force using the breaker bar ?
    thanks
    Ok - according to the serial number on my water heater it is really 13 yrs old. I successfully replaced the dip tube - and after 3 weeks of applying liquid wrench the anode nut finally broke loose. Only about an 1/8" rod maybe 15" was all that was left of the original anode rod.
    So I installed the new anode rod - it was magnesium - is this the correct type of material for my region ? I live in Westminster Colorado and my water comes from a high country stream which fills a local resevoir.
    The magnesium rod cost me $ 25 - the plumbing supply place was out of alumimun.
    If the water heater dies in the next few years - remind me to remove the anode rod for use in my next water heater. Am I beginning to think like a plumber ?
  2. hj
    anode
    If the heater lasts until it is 15 years old, it could be because of the new anode rod. Without replacing the anode rod the heater might only have lasted 1 1/2 decades. And the same may be true for the replacement heater regardless of whether you maintain the anode or not. New heaters can last 1 year, 3 years, 6 years, or 14 years, and that is without any maintenance of any king.
Similar Threads: Anode magnesium
Water Heater Forum, Tanks Powered anode rod to replace magnesium anode Mar 7, 2013
Water Heater Forum, Tanks Anode rods...Magnesium vs Aluminum Oct 20, 2012
Water Heater Forum, Tanks Where to find Magnesium Anodes for 50 Gal Gas GE/Rheem? Model PG50T9A....Thanks! Jan 25, 2012
Water Heater Forum, Tanks Anode Rod Aluminum broken in two; can't get rod out of tank! Feb 11, 2017
Water Heater Forum, Tanks Anode rod under hot outlet? Ao Smith GVR 50 300 Nov 1, 2016
