Anode replacement Kenmore Power Miser 6 Gas Water Heater.
Discussion in 'Water Heater Forum, Tanks' started by oz19454, Apr 4, 2010.
  1. oz19454
    oz19454 New Member
    Apr 4, 2010
    PA
    I called the local plumber store. they said Kenmore Power Miser 6 Gas Water Heater need to order from Sear. But I looked at the video. He said it is standard pipe. Since Sear do not have collapsible type. I am wondering whether I can use different anode. Thx.
    http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
  2. hj
    Sears does NOT make water heaters. Depending on its age it was either made by State or AO Smith, which are essentially the same now. Either one uses a standard anode rod, and you can use any type which will work, usually the segmented ones are easier to insert.
  4. oz19454
    oz19454 New Member
    Apr 4, 2010
    PA
    Well. I ordered from Sear already. I think it is too long. May I cut that short ? Thanks.
  5. jadnashua
    The anode rod works by the amount of surface area, so, if you cut it off, it will still work, but not quite as long or as well. Still, likely better than an old one that has been eaten away (they call it a scarficial anode for a reason!).
Similar Threads: Anode replacement
Water Heater Forum, Tanks AO Smith GPSH 50 100 Anode replacement Sep 15, 2012
Water Heater Forum, Tanks Bradford WhiteAnode Replacement Jul 21, 2011
Water Heater Forum, Tanks Anode rod replacement on AO Smith Heater Aug 29, 2010
Water Heater Forum, Tanks anode replacement-what kind. Apr 14, 2010
Water Heater Forum, Tanks Replacement Anode for AO Smith Jan 3, 2010
