Molo
Hello all,
I am putting the tank on the bowl of an American Standard Cadet. It is not the bolt/washer set-up that I am use to. It has rubber washers under the bolt head inside the tank, and that is it for washers. The 2 bolts go through a hole in the bowl and then a metal washer and nut pull the bowl down.
1. How do I know when the bowl is tight enough? I don't want to crack the porcelain, but I want to ensure the rubber washer is sealing the tank.
TIA,
Molo
TIA,
Molo
