aluminum pipe for water?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbillcee, Feb 19, 2011.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    can i use threaded aluminum pipe for say a 12 inch piece of pipe to the shower head?
    the standard 8 in 45 degree they give u is shooting the water out of the tub so i wanted to make a sharper bend on a longer nipple to adjust it,
    they had something at the plumbing supply that would work but it was 50 bucks!
    i am open to other ideas!
  2. hj
    It might not be the best idea you ever had. Aluminum can deteriorate and it is softer than brass so it can bend or break easier.
  4. jimbo
    jimbo Plumber
    Any problem in plumbing can be solved by applying the appropriate amount of cubic dollars.
    Even if you find aluminum pipe with the correct threads, I don't think it is all that easy to bend! And the soft threads will probably leak!
  5. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    hehe i am electrician and we thread and bend thick walled aluminum pipe so i figured what the hey!
    anyway i found a satin nickel one for like 40 bucks shipped thanx for input
Similar Threads: aluminum pipe
Plumbing Forum, Professional & DIY Advice Aluminum Pipe Wrenches Feb 14, 2010
Plumbing Forum, Professional & DIY Advice Aluminum pipe wrenchs Sep 23, 2006
Plumbing Forum, Professional & DIY Advice What do I have? Black poly with aluminum tube liner. Oct 29, 2010
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Thursday at 10:11 AM
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Wednesday at 10:33 PM
