Air Gap is leaking
Rami2022
Walnut Creek, CA
I installed a new sink and the plumber did a totally new connections between the sink, dishwasher. Air gap, etc. (No Garbage disposal has been installed). Two weeks after the installation I am getting water coming from the air gap when I run the dishwasher. (I rinse everything before i put it in the dishwasher to remove any food particles).
When I called the installer I have been told that: "This is common with sinks that do not have a garbage disposal, as food can get stuck in the p-trap".
1. Is this a true statement, or just an excuse on their part ?
2. Can this (block of the air gap) happen in 2 weeks time frame?
Thank you,
Rami
Tuttles Revenge
That doesn't make any sense at all... a disposer is connected to a p-trap.. so that is just a lame excuse.
Yes, anything can happen.
How is the air gap connected? The dishwasher hose which is usually clear/translucent/gray should be connected to a vertical port on the bottom on the Air Gap. The dishwasher pumps up into the air gap and then the waste falls down the gravity drain to the sink drain or disposal. That hose is typically a black rubber hose and should not have any kinks or bellies in it. It needs to have a nice gentle downward slope from the air gap to the drain connection.
Rami2022
Walnut Creek, CA
This is how it looks under the sink....
Tuttles Revenge
I don't see anything wrong with the installation. It looks perfect. Perhaps taking the decorative cap off the air gap and opening up the top to see if there is any chance a piece of debris is stuck in it.
