I've searched everywhere and cannot fine a good answer. I just bought a 80 gallon 240v compressor and now I'm Running the electrical. I installed a 30 amp double pole breaker with 10 gauge wire to the outlet.
My question is with making the "power cord" for the compressor. Since I ran 10 gauge wire on the 30 amp breaker, I would assume I would use 10/3 SJOOW wire. The motor's plate says the amp rating is 22 amps. However when looking at the factory wiring between the motor and the pressure switch (I guess that would be considered the motor's power cord) it's 12 gauge wire. I would have thought for a 22 amp motor, they would have used 10 gauge. Why is it they used 12 gauge instead of 10? Because of this, can I use 12/3 SJOOW wire for the power cord? I have both 10 and 12 SJOOW gauge wire on hand and know the logical solution is to just use the 10 gauge but I guess I'm more so curious if i'm allowed to use it (the 12 gauge that is). It seems If the motor manufacturer can use 12 gauge for a power cable on their 22 amp motor, why couldn't I use it?
The receptacle on the wall and the plug are rated for 30 amps
