Air balancing system
Discussion in 'HVAC Heating & Cooling' started by docaudio, May 13, 2009.
  1. docaudio
    docaudio New Member
    Jul 29, 2007
    Audio Post Production
    North Tustin, CA
    Hi,
    I've been pondering an air balance system to install in our mountain cabin. The plan is to create 2 plenums in the corners of two outside walls that run vertically from 1st to 2nd floor, with an inlet near the ceiling of the 2nd floor, a duct fan near the inlet, and an outlet near the floor on the 1st floor. We have lower level bedrooms and living area is on 2nd floor. Even heat has always been an issue between floors. I just thought this could help a bit, but am wondering about code and fire issues. This will be a permitted job (bundled with an existing remodel), but wanted to get some preliminary info before getting too far along.
    Below is a quick plan..
    [​IMG]
    -Bill
Similar Threads: balancing system
HVAC Heating & Cooling Balancing my HVAC system? Dec 12, 2016
HVAC Heating & Cooling Radiant heat and domestic water on same system? Feb 13, 2017
HVAC Heating & Cooling Ducted and ductless mini split system installation cost - reasonable? Jan 17, 2017
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling Help! - new system is not cooling adequately Jul 14, 2016
