Advice: Winterizing frost-free faucets
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Buffalo Hunter, Jul 8, 2008.
  1. Buffalo Hunter
    Buffalo Hunter New Member
    Jul 8, 2008
    I am going to replace my old sillcocks with frost-free ones. Do I still need to winterize them each year (turning off shut-off valve & leaving them open)?
    Also this website says that frost-proof sillcocks won't work in houses built on concrete slabs. Why is that?
    http://www.rd.com/familyhandyman/content/18060/
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Is your pipes going to be inside the slab?
    I would still install one. I don't take advise from any handyman. They know enough to get them selves into trouble. I know some are real good and do try to follow codes, but not many.
    If you install your sillcock right it will not freeze in the winter.
  4. Buffalo Hunter
    Jul 8, 2008
    No pipe is 2" above slab
  5. jadnashua
    The whole idea with a frost free silcock is that the actual guts that shuts the water off is at the long end of the handle, way at the base. They comde in various lengths to accommodate different wall thicknesses. So, when you shut the water off, it is already way inside the wall so normally, an internal shutoff is not required. You MUST remove any hoses, so that the water left in the outer part of the valve can drain. The thing should be installed with a little slope to drain, but enough will to keep it from splitting unless it is sloped severely backwards towards the house.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    No winterizing as such needed, but do not leave a hose connected in the fall. If you do, the water will not drain out of the pipe and it will freeze and split the pipe. You won't even know it until you attempt to use the valve in the spring because a previously noted, the actual shut off occurs inside.
Similar Threads: Advice Winterizing
Plumbing Forum, Professional & DIY Advice Need advice on winterizing house Nov 17, 2010
Plumbing Forum, Professional & DIY Advice Advice on stack and main line Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Advice on bathroom sink drain Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Polypropylene for Drain/Waste/Vent Installation Advice? Jan 4, 2017
