Advice on Shower Panel
Discussion in 'Shower & Bathtub Forum & Blog' started by moobiker, Aug 16, 2006.
  1. moobiker
    moobiker New Member
    Aug 13, 2006
    Boise, ID
    Doing a remodel on master bath. Just beginning to explore the myriad of options on shower panels. Anybody have any advice/insight on jetted shower panels? Which one's to favor, which to stay away from? Any particular installation issues associated with particular panels? Thanks
    Mike
  2. jadnashua
    Nothing specific, but keep in mind the supply pipe size and the volume of hot water you can use. Decent pressure AND volume along with a likely large hot water supply may be needed to properly appreciate that type of appliance. Look at the gallons/minute it needs and check the recommended supply. You dont' have to get a pre-engineered panel, there are numerous manufacturers that make components that you can install to meet your specific needs/desires. If you are going to tile things, you might want to check out www.johnbridge.com
  4. moobiker
    moobiker New Member
    Aug 13, 2006
    Boise, ID
    Thanks Jim
Similar Threads: Advice Shower
Shower & Bathtub Forum & Blog Can't get trim off shower handles... advice? Apr 12, 2016
Shower & Bathtub Forum & Blog Advice for cast iron hub shower drain connection Mar 6, 2016
Shower & Bathtub Forum & Blog Need a little advice, building shower pan Mar 3, 2016
Shower & Bathtub Forum & Blog Advice on changing two handle shower valve Feb 5, 2016
Shower & Bathtub Forum & Blog Advice on what to do with rusty drain in Shower Stall Dec 22, 2015
