Adjusting receptacles due to new tile
Discussion in 'Electrical Forum discussion & Blog' started by Southern Man, Oct 22, 2008.
  1. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    How do I adjust this? An extender box does not fit.
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    An Arlington BE1 box extender will fit that application.
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Since the tile is fireproof can't he just use standoffs?
  5. Southern Man
    Jun 27, 2008
    North Carolina
    [​IMG]
    Those won't work. The edge of the tile goes over the sides of the box underneath.
  6. Southern Man
    Jun 27, 2008
    North Carolina
    Can I get them at the local big box? I already looked for something like that at Slowes with no luck.
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Then have your tile guy come back and fix his screw up. The tile should NOT be past the box edge.
    The BE1's are smaller than the box and are tapered. They might fit. Unless the tile is considerably inside the box they usually do.
    Combustible or not, I like to use them.
  8. B2CHR
    B2CHR New Member
    Jul 1, 2008
    Remodelng
    Central NC
    Yea tile job messed up to start with. I always run my tile down to the outlet mounting screw so the outlet will lay on top of the tile. In this case I would cut a small piece of tile to slip up under the outlet "wings" and tighten the outlet down on them and install a larger face plate.
  9. rayh78
    rayh78 Member
    Sep 15, 2008
    Colonial Heights, Virginia
    look at
    www.rd.com/familyhandyman/content/19468/
    or buy the spacers made for this at H Depot, think lowes has to.
  10. Southern Man
    Jun 27, 2008
    North Carolina
    He took 6 days for a 3 day job and I don't want to clean up after him a 7th time. Besides the tile is a "crackled" finish and would probably fall apart if he tried to dry cut them.
    I'd like to use the extenders too, and bought a few for where I can fit them without cutting them all up.
  11. Southern Man
    Jun 27, 2008
    North Carolina
    Found 'em at Depo' this morning, hiding on a bottom shelf. Thanks!
  12. Southern Man
    Jun 27, 2008
    North Carolina
    Spacers worked great. They are rubbery plastic and connect together like legos. I had to use between 5 and 9 layers, depending on the locations.
  13. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Universal spacers:
    a 1/4" copper tube and tubing cutter and you cut to length on the job-
    or, 1/4" plastic humidifier pipe, you cut with knife, same deal-
    You can also wrap your own spacer with coat hanger wire but it strongly resists this treatment. If you have a gas flame, heating the wire red hot and letting it cool takes the argument out of it.
    Don't forget your long 6-32 screws.
Similar Threads: Adjusting receptacles
Electrical Forum discussion & Blog Adjusting wall plates - Moving switches & receptacle outward so wall plate looks good Dec 29, 2009
Electrical Forum discussion & Blog 15 amp arc fault receptacles on 20 amp circuits? Sep 5, 2016
Electrical Forum discussion & Blog 12/4 to run constant and switched receptacles in 2 gang boxes Apr 2, 2014
Electrical Forum discussion & Blog Kitchen peninsula receptacles under 42" bar countertop with 13" overhang Feb 23, 2014
Electrical Forum discussion & Blog Ignorant question, business replacing receptacles and switches. Oct 28, 2013
