Adjusting Float Ball in Toto Toilet
Discussion in 'Toilet Forum discussions' started by memphisliza, May 8, 2005.
  1. memphisliza
    memphisliza New Member
    May 8, 2005
    We have a new Toto toilet, and it continues to run after being flushed. When I look inside the tank, the water is right up to the top of the overflow tube and running down. If I lift up the float ball a little bit, the water stops running and when I put the ball down, it stays off, but the water is right up to the top of the overflow tube. I'm not sure what to adjust, but clearly I need to turn off the tank fill valve sooner. Thanks for any help.
  2. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    When looking at the top of the fill valve you'll see a screw there....right smack dab on top. Turn it clockwise to decrease the water level in the tank.
    good luck
  4. memphisliza
    May 8, 2005
    Thanks, worked great
    thanks, it was very obvious how to adjust the float until the water level reached the line marked "water fill". Can't believe it was so easy. Thank you for such a quick reply.
Similar Threads: Adjusting Float
Toilet Forum discussions Adjusting Tank Filling Time? Dec 12, 2009
Toilet Forum discussions Toto Fill Valve Problem Continues G-Max valve with adjusting screw Nov 30, 2008
Toilet Forum discussions Adjusting Water Level in Toto Drake Bowl Nov 20, 2005
Toilet Forum discussions adjusting water level in Toto toilet Nov 14, 2005
Toilet Forum discussions Adjusting AS Vent-Away toilet venting system Sep 14, 2005
