Adding washing machine to drain line
Mark Jones
I have a drain 1.5" line with p trap from the kitchen to the exit 2in pipe. There is also a dish washing machine plumbed into the sink drain line.
I am adding a clothing washing machine beside the dish washer and would like to plumb into this line.
SHOULD I add a 2nd dedicated drain line from the clothing washer to the exit down line to sewer OR can I tie into the existing line?
THANKS
Gary Swart
Yakima, WA
Washer drain
A clothes washer requires a 2" drain. The sink and dw drain is only 1-1/2", so you'd be open for real problems. Add a 2" trapped standpipe for the clothes washer.
Deb
Idaho
Deb
Actually, the kitchen sink drain should also be 2", so it is already undersized. The washing machine drainage must be done correctly. The p-trap should be 6-18" off the floor. The standpipe 18-30" in height. This must also be vented through the roof or tie in with another vent 6" above the flood rim level of the fixture. Install a cleanout--lint can be a problem in washing machine drainage lines.
Deb
The Pipewench
