Adding Utility Sink - Trap Height Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by kucharskimb, Oct 12, 2005.
  1. kucharskimb
    kucharskimb New Member
    Oct 12, 2005
    Houston, TX
    Hi, from the New Guy...
    I would like to add a utility sink in my garage. The area that i would like to install is on the opposite side of the wall that has the washing machine.
    the washing machine has a vertical drain, which then runs horizontal for 18" before teeing into the vent-waste stack (1). below this tee, there is a clean out. the cleanout is just above the bottom wall plate (2). directly below the wall plate, the vertical drain turns horizontal, and heads for the main waste line (3).
    the problem is that (2) is about 18" above the garage floor. i don't think the utility sink legs are tall enough to allow me to tie in high enough into the stack, even if i make the down tube to the trap very short.
    what is the lowest point that i can tie in my trap to this dwv?
  2. hj
    drain
    I hope you have not drawn the drain exactly as it is installed, otherwise there is no trap on the washing machine drain. You can install the tee up to a point about 3" below the sink's bottom, but that gets pretty tight to make the connection.
  4. kucharskimb
    Oct 12, 2005
    Houston, TX
    thanks for the reply. i guess my question is less of the sink question, and more of the tie-in question...
    how low in my drawing can i tie-in a sink drain?
    can i put a double Y at the clean out (2)?
    can i put a Y where it turns horizontal (3), and continue the horizontal to my sink?
Similar Threads: Adding Utility
Plumbing Forum, Professional & DIY Advice New member, Adding utility sink on opposite wall of bathroom Apr 7, 2016
Plumbing Forum, Professional & DIY Advice Adding utility sink to washer drain Sep 23, 2015
Plumbing Forum, Professional & DIY Advice Help: Adding new Utility Sink and Washer Waste Wipe May 22, 2015
Plumbing Forum, Professional & DIY Advice DIY'er adding a sink in a utility room with washer/dryer Mar 3, 2015
Plumbing Forum, Professional & DIY Advice Adding garage utility sink - use existing 1st floor bathroom drain and vent? Nov 13, 2014
