Accor Flow-Tite valve question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rudyjr, Jan 12, 2013.
  1. rudyjr
    rudyjr New Member
    Jun 3, 2012
    central ohio
    Recently I removed and reinstalled two toilets for my sister in her condo so that flooring could be laid. I found that her condo of eleven years was plumbed with cpvc and had the push pull Accor stops with the supply line permanently attached. One supply line now has a leak where it is connected to the valve, what a fine piece of junk these appear to be. I have searched the site and seen that these have a known problem with this issue. In doing some further investigation I have found that I have three family members living in residences built in the last 12 years that have cpvc and these things installed in them. Can anyone give me a good solid recommendation on a quality brand specific replacement valve that I can replace these with. I understand that these can be a real PIA to get off of the pipe without damaging it so I will have my hacksaw and die grinder with cutoff blade handy when I start this. I have 45 of these to do in all so I want to only do it once. Thanks for the help.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    First thing you had better do is to verify with the condo association that they will allow a non professional to work on the plumbing. Most, if not all, will not allow a non licensed plumber to touch the plumbing or electrical due to liability issues. Even if they will permit you to do this work, just one error that flooded a unit or two could cause a lawsuit that would bankrupt you.
  4. rudyjr
    rudyjr New Member
    Jun 3, 2012
    central ohio
    Good legal advice. Thanks
Similar Threads: Accor Flow-Tite
Plumbing Forum, Professional & DIY Advice Accor Flowtite Valves...leak...totally clueless new homeowner Oct 28, 2016
Plumbing Forum, Professional & DIY Advice How Do I Remove Accor Plastic Push-Pull Supply Valves? Jun 21, 2014
Plumbing Forum, Professional & DIY Advice Removal and Replacement of ACCOR FlowTite Shut Off Valves Sep 24, 2013
Plumbing Forum, Professional & DIY Advice vikrell accord shower wall Mar 7, 2009
Plumbing Forum, Professional & DIY Advice Which PEX sizes according to ... Jul 6, 2008
