Access to tub faucet - size of hole in drywall?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by AcidWater, Nov 7, 2012.
  1. AcidWater
    AcidWater Member
    Oct 14, 2008
    How big a hole do I need to cut behind the tub faucet to replace it? Want plenty of working room.
    The valves are 24" above the floor, the spout about 19". 3 valve type with 8" spacing.
    the big question is: How much above & below that should I allow to get to the unions, if present? I want to cut a single piece of drywall out so I can replace it easily.
    Its in a closet so I can go large... stud indicator says there's a stud in the middle.
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Go stud to stud on the two outside studs that always does it for me
  4. hj
    Getting to the unions is not the problem because they are right below the hot and cold stems. Piping to the new valve is where you may have problems. If you go below the tub spout, 6" above the hot and cold handles, and stud to stud, you should be fine.
  5. AcidWater
    AcidWater Member
    Oct 14, 2008
    Okey Dokey. Hopefully the replacement will fit the existing unions.
  6. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    That's not going to happen. Most new three valves, if you can find one no longer have unions. Even if they did they wouldn't fit the old ones.
    John
  7. hj
    They MIGHT fit if the new faucet is the same make as the old one, but even then they sometimes change the patterns to make them "lighter", (i.e., cheaper).
  8. AcidWater
    AcidWater Member
    Oct 14, 2008
    How do union joints differ? Are they brand proprietary?
    Gotta cut the hole in the wall today...
Similar Threads: Access faucet
Plumbing Forum, Professional & DIY Advice Tub shoe gasket replacement when no access? Oct 5, 2016
Plumbing Forum, Professional & DIY Advice Heard Noise Behind Tub. No Access to Failed Part. How Hosed Am I? Nov 29, 2015
Plumbing Forum, Professional & DIY Advice Possible to use Ikea vanity if water and drain access on side? Sep 30, 2015
Plumbing Forum, Professional & DIY Advice Ceiling Access Panel??? Jul 26, 2015
Plumbing Forum, Professional & DIY Advice Access Panel vs Drywalling Jun 1, 2015
