A/C Slab
Discussion in 'HVAC Heating & Cooling' started by burkhamerk, Apr 16, 2011.
  1. burkhamerk
    burkhamerk New Member
    Apr 16, 2011
    U.S. Army Civilian Employee
    Missouri
    Slab under A/C Unit degrading and rear of slab sinking. A/C unit now sits at angle with rear of unit lower than front. How severe is this problem? Wondering if I should disconnect/move unit and pour a new slab.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Most A/C places do not pour cement, they just bring in a prefabricated 3x3 slab that is available from most supply houses.
    If the condenser gets too far out of level it can effect the oil flow through the system. How much is "too much" is speculative.
  4. jadnashua
    If it sinks too far, it might kink or stress the coolant lines. That can be really bad. Otherwise, close to level should be okay...hard to say how much off will cause problems.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I would just lift the slab back up to level and shove some sand under it.
  6. tempritespokane
    tempritespokane New Member
    May 3, 2011
    Spokane, Washington
    If the slab in not level it also can make your unit run less efficiently. In the long run it can run up your electric bill.
Similar Threads: Slab
HVAC Heating & Cooling Radiant in slab heat questions Jan 8, 2017
HVAC Heating & Cooling In floor Radiant heat not working (under concrete slab) Jan 3, 2017
HVAC Heating & Cooling Connecting a new radiant heat zone for a garage slab to an existing baseboard boiler heating system Nov 12, 2014
HVAC Heating & Cooling Wirsbo hePEX in slab repair - PROPEX or QS20 Compression? Apr 7, 2014
HVAC Heating & Cooling Radiant for new slab_need advice for an easy cheap way to supplement F/A htg in 3 rms Mar 7, 2013
