I installed a 9100SXT dual tank about a month ago with no issues. Today it developed a good leak right at the 3/4" Plastic Turbine Meter Assembly that goes into the softener and into the bypass. The tank being used was the tank that was first regenerated with it about to regenerate again. It wasnt moved or anything so not sure why it started leaking all the sudden? Could something be cracked or clogged that maybe cause a pressure build up? I pulled it a part and reattached everything with the same leak. Any ideas of what to check?
Thanks,
Thanks,
