9 inch rough in toilet needed... or ideas.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dhornick, Oct 18, 2007.
  1. dhornick
    dhornick New Member
    Oct 18, 2007
    Kansas City, MO
    Help. I’ve created myself quite a mess. We’re remodeling a down stairs bathroom. I removed what was a fine working no problem toilet with the thoughts that if we’re remodeling we might as well do it right and do it all. However, now I find out there are different rough in toilet sizes that come standard in 10, 12 and 14 inches. As best as I can tell mine is 9 and maybe 9.5 if I really stretch it. I have called all major plumbing supply houses in the area and even the manufactures but no one evidently makes a 9 inch rough in toilet.
    The all say a 10 inch might work but â€might†is an awful expensive word to bank on. Any one have any ideas? :confused:
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Change the drain so that you have a 12" rough in then virtually any toilet will fit.
  4. MG
    MG New Member
    Jun 29, 2005
    Illinois - Near St. Louis
    You are measuring from the center of the drain to the wall, correct?
  5. jadnashua
    Measure exactly how far it is from the mounting bolts to the finished wall. That is your rough-in dimmension. then, check the manufacturer's spec sheets for any toilets you are interested in. They will show how much gap there is between the toilet and the wall when installed on a standard rough-in. That is your leaway. Note, go to the wall, not the baseboard.
    Move the drain, and this problem goes away.
  6. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Most 10" rough in toilets will have a gap between the wall and the back of the tank. On most toilets it is 3/4", so if you push a 10" up against the wall you can go as close of 9-1/4".
  7. dhornick
    dhornick New Member
    Oct 18, 2007
    Kansas City, MO
    Yes, correct.
  8. dhornick
    dhornick New Member
    Oct 18, 2007
    Kansas City, MO
    Moving the drain is not an option.
  9. dhornick
    dhornick New Member
    Oct 18, 2007
    Kansas City, MO
    Thanks Peanut9199, this is what I'm leaning towards trying and really really hoping it works. After all there was a working toilet there before so something has to work.
Similar Threads: inch rough
Plumbing Forum, Professional & DIY Advice 4 Inch PVC Sewer Line Through Cinder Block Foundation Wall In Crawl Space Oct 8, 2012
Plumbing Forum, Professional & DIY Advice we have a 16 inch rough-in andcannot find a tolet ith a 16 inch roughin anywhere Nov 17, 2011
Plumbing Forum, Professional & DIY Advice 13.5 inch rough in toilet replacement help Jul 30, 2005
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Support studs in bathroom need new how do i thread 2 inch pvc pipes thru them Feb 1, 2017
