50A receptacle on 40A circuit okay?
Discussion in 'Electrical Forum discussion & Blog' started by Taylor, Sep 28, 2010.
  1. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    Ok to put 50A receptacle on a 40A circuit, #8 wire? My understanding is that NEC allows derating of 50A range on the belief that normally one will not have all rings and ovens going at once. And #6 wire is a PITA hooking up to a receptacle in a junction box.....
  2. Cookie
    Cookie .
    Oct 7, 2005
    The Amps that the fixture will draw are found on the rating plate on the fixture. Use the corresponding outlet wire and breaker required for the fixture.
  4. Ian Gills
    Jul 24, 2007
    USA
    I've never seen a 40 amp range receptacle. But like Cookie says, what is critical is what the load requires.
    Nearly all residential ranges require only a 40 amp circuit.
    40 and 50 amp breaker/circuit are basically interchangable. You can use either for a 50 amp receptacle.
  5. Cookie
    Cookie .
    Oct 7, 2005
    Range plugs have a specific configuration based on their amps.
  6. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    My stove...if everything were on...could pull 58a
    Based on the nameplate rating
  7. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    Thanks all. Rex Cauldwell's Wiring for Pros says that NEC allows derating a 50A range to 40A on the basis that homeowners will never have everything on on the range. So you would run #8 wire from a 40A circuit to a 50A receptacle and plug in a 50A range.
    Cauldwell disagrees with NEC on this, but having tried to wire up a receptacle on #6 wire in a junction box, I can understand why this might be useful.
    In my case, I am looking at a 40A dual fuel range. I was interested in up-sizing for future needs, until I tried it. Just wanted to make sure I did not have to replace the receptacle.
  8. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Any household cooking appliance rated 12kW or less can be used on a 40A circuit.
    Also, to answer the original question, yes, a 50A receptacle can be used on a 40A circuit wires with #8. 40A receptacles do not exist.
  9. hj
    THe amp rating of the receptacle is immaterial. The circuit breaker size is determined by the wire, and as long as those two are proper, you can put any recepacle you want on the end of it. IF you overload the circuit, it will trip the circuit breaker, and that is its function.
  10. Speedy Petey
    Jun 16, 2007
    NY State, USA
    This is not really true. There are strict paramaters as to what receptacles can be used on certain circuits.
    See NEC 210.21(B)(1), 210.21(B)(3) and T210.24
  11. jadnashua
    While it may not happen too often, but imagine that big party when you've really got all the burners on, and the breaker trips when you don't realize it...could make for a nasty end result. While maybe you can, doesn't always mean you should.
  12. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I've wired a lot of ranges on 40A circuits and I have NEVER heard of this happening. Have you?
  13. jadnashua
    No, I've not seen it happen. But, his dataplate indicates 58A at full draw. It is unlikely that all burners would be on high, but possible. That's a bit over what a 40A circuit should safely support. Most of my personal experience is with gas stoves...some of the newer ones have more burners, and higher wattage than a typical generic stove.
  14. hj
    quote; That's a bit over what a 40A circuit should safely support.
    Actually ANYTHING over 40 A, is more than the circuit can safely support, which is WHY the circuit breaker should be sized for the wire, NOT the anticipated load.
    That paragraph says that the receptacle cannot be rated LESS than the circuit breaker's capacity, and here is a quote from another area
    A 30A receptacle may be placed on a 25A individual branch circuit. As could a 50A receptacle.
    Which restates what I said previously.
  15. Ian Gills
    Jul 24, 2007
    USA
    You did not say that. You said you could put any receptacle you want on a circuit as long as the breaker and the wire are sized correctly.
    You could not put a single 15 amp receptacle on a 20 amp circuit, for example. At least I wouldn't.
    Common sense.
  16. hj
    My mistake. My implication was that he could put HIS oversized receptacle on the end of it, since that was his question.
  17. jimbo
    jimbo Plumber
    San Diego, CA
    Just remember.....anything you say after hj has the last word, starts a new thread completely!
  18. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    I realize this is quite correct as far as the NEC, but the logic of it escapes me.
    I don't see how a 15-amp receptacle on a 20-amp circuit is a safety hazard. What am I missing?
  19. jadnashua
    Most receptacles can pass through more current than they can source at an individual outlet and Ian is wrong...you can use 15A devices on a 20A circuit. Although, if you have some one thing that can monopolize the circuit's max current, it's sort of nice to size the outlet for that user.
  20. Artie
    Artie New Member
    Nov 6, 2009
    Jacksonville, Fl
    For what its worth, twice a year, (Thanksgiving and Christmas), pretty much every burner on the cooktop, and both ovens of the double oven, are going full speed. ;)
  21. jimbo
    jimbo Plumber
    San Diego, CA
    IN THEORY....a 15 amp equipment could have an internal fault, and since the breaker wouldn't pop until 20, damage or overheating could occur since internally, the equipment is designed to be protected by 15 amps max. This is a stretch of an argument, and the NEC apparently feels comfortable enough to allow it. I do understand that the Canadian Electrical code does NOT allow it.
Similar Threads: receptacle circuit
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Feb 22, 2017
Electrical Forum discussion & Blog 15 amp arc fault receptacles on 20 amp circuits? Sep 5, 2016
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Mar 19, 2017
Electrical Forum discussion & Blog 240v receptacle conversion Apr 7, 2016
Electrical Forum discussion & Blog How does the Receptacle , the wiring, CB and code Relate? Mar 18, 2016
