4 way switch
Discussion in 'Electrical Forum discussion & Blog' started by eljefedavies, Mar 16, 2009.
  1. eljefedavies
    eljefedavies New Member
    Mar 16, 2009
    Nevada
    I am trying to tie 2 lights together with 3 switches. The first light will have a 3 way switch near it, then a 4 way switch, then a 3 way switch and finally the second light. I know how to wire it by having both lights at the end of all the switches. However due to this being a remodel I am trying to minimize the running of wires. all lights and switches are currently in. 1 switch is controlling 1 light (the first 1 in the above question). The other light is being controlled by 2 3 way switches ( 1 will be changed to a 4 way (#2) and the last 1 will remain a 3 way (#3). Any help especially diagrams would be great. Thanks
  2. thassler
    thassler Member
    Dec 5, 2006
    Systems Analyst
    Tennessee
    The answer would depend upon where the power source starts (switch box or light fixture) and if onward unswitched power is needed and from where. Here's a link to several ways of wiring 4-way switched power:
    (If linking to another site is not allowed, Moderator please remove.)
    http://www.selfhelpandmore.com/switch-outlet/4-way/
    You can also google "4-Way Switch Wiring Options"
    **Not a pro - only a DIY
  4. rgsgww
    rgsgww New Member
    Jul 5, 2008
    Ia
    This is one way you could do it...It might not work in your situation....
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    You have a violation of Section 200.7(C)(2) of the NEC.
    There will be a reinspection fee for this.
  6. rgsgww
    rgsgww New Member
    Jul 5, 2008
    Ia
    My understanding of section 200.7(C)(2) is that the white,gray, or marking of three continuous white stripes on a conductor, the conductor must be used for the supply, not the return.
    Using it as the supply means that it must be permanently marked with paint or other means.
    My image was wrong, so I deleted it.
    This should be right?
  7. eljefedavies
    Mar 16, 2009
    Nevada
    This looks like it may work, a few questions though.
    1. Why use the red wire then change to black? isn't the white one normally used then marked with black tape.
    2. Where the 2 wire branches off the feed for the light, it looks like this is spliced in, can this be done? I would be able to do this in the 3 switch box, this would solve my problem. I am trying to avoid running a 2 wire from one light to the next due to ,locations and insulation etc...
  8. rgsgww
    rgsgww New Member
    Jul 5, 2008
    Ia
    You can use the red wire or black wire for the returning switched power, not the white. The white can only be marked and used as a supply conductor. As defined in 200.7(C)(2)
    200.7(C)(2)
    Where a cable assembly contains an insulated conductor for single pole, 3-way or 4-way switch loops and the conductor with white or gray insulation or a marking of three continuous white stripes is used for the supply to the switch but not as a return conductor from the switch to the switched outlet. **Or light** In these applications, the conductor with white or gray insulation or with three continuous white stripes shall be permanently re identified to indicate its use by painting or other effective means at its terminations and at each location where the conductor is visible and accessible.
    You can splice two wires from the switch box, but you need to watch box fill.
    What type of lights are these? cans can usually accept two romexes.
  9. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Maybe this will help
    this one is from the panel or some other place like a rec. or another switch
    [​IMG]
    This one is if the power is at the light
    [​IMG]
    if you have any more questions I feel sure someone will answer but I have to go for now
  10. hj
    circuits
    ALL light circuits have the switches at one end and the light at the other, regardless of how they are physically located. The two 3-ways could be next to each other and the 4-way at the other end of the house, but they would still have to be daisy chained together as if they were located right next to each other. You have to think about the way the switches have to be wired together, NOT where they are located relative to the light fixture.
  11. eljefedavies
    Mar 16, 2009
    Nevada
    Thanks for all the help. I have it all completed, I was just hoping to minimize the pulling of new wires, but it wasn't as hard as I anticipated.
Similar Threads: switch
Electrical Forum discussion & Blog Transfer switch connections Mar 22, 2017
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Mar 19, 2017
Electrical Forum discussion & Blog Lights will not turn on using 3 way switch Mar 5, 2017
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
