4 Gang Switch Box Wiring diagram
Discussion in 'Electrical Forum discussion & Blog' started by ChrisNJ, Mar 30, 2013.
  1. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Hey all. Other than my poor artistic skills, spelling and use of scrap paper does this plan look acceptable? This is a dedicated 15 amp circuit on a GFCI breaker (it's gonna be in a bathroom) straight from the panel using 14-2 NM. Black is hot, blue neutral, green ground.
    [​IMG]
    For the three 5 wire connections in the switch box, I was going to use Ideal 452 Wing Nuts in red for hot and neutral wires but I'm not sure if I can use those for the ground wire.
    As an alternative, can "rabbit ear" connections still be used rather than the 452 nut? Any suggestions or criticisms will be most appreciated. Thanks!
  2. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Ground wire (EGC) connections are no different than any other wire connections. Never heard of "rabbit ears", but if its a listed wire splicing device,
    and has the capacity for the number and size of wires,
    it should be fine. You need to ensure the switch device yokes are grounded, which may possibly require connection to the EGC.
  4. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Thanks! Is it acceptable to pigtail the EGC to the 4 switches as long as I don't exceed each individual splice's capacity? For example:
    [​IMG]
    How's that look? Or do you have a suggestion? I'm all ears.
  5. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    It's not only acceptable, it's required if you're using a plastic box. There are many ways to physically attach the wires, what you show looks fine.
  6. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Thank you so much for your help. I owe ya a beer :)
  7. hj
    The color of a "wire nut" is a function of its size and capacity. I have a feeling that you are going to run out of "box capacity" very quickly if you make ALL those spices you show.
  8. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    I hope not. Using pretty good size box.
  9. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Push-in (Wago-style) connectors are handy for making those pesky ground connections; you can get 'em with up to 8 holes.
  10. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    You can cut down on the number of wires in the switch box by going with 14-3 to one device box with two switched hots and then continuing on with 14-2 to another.
    Hope that makes sense...
  11. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    That is the way I would do it.
  12. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    It does. That will save a ton of box space. Thanks.
  13. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Gonna grab some of those too since all the stuff I'm connecting doesn't draw too many amps.
  14. Homeownerinburb
    Homeownerinburb New Member
    Jan 14, 2012
    Los Angeles, CA USA
    You can also save lots of wire by daisy-chaining the common hot and the ground. One wire long enough to go from one switch to the next, with enough insulation removed to wrap around a screw. Not cut, continuous across the screw to the next switch.
    Very much a pain with 12 ga, but everything is a pain with 12 ga. Happily you are using 14 ga, which makes all this much easier.
  15. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    You can also save lots of space by daisy-chaining the common hot and the ground. One wire long enough to go from one switch to the next, with enough insulation removed to wrap around a screw. Not cut, continuous across the screw to the next switch. Don't damage the conductor.
  16. ChrisNJ
    ChrisNJ New Member
    Feb 24, 2007
    NJ
    Will that pass inspection?
  17. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    I did that here and it passed -- but the inspector didn't look that closely in every box. Here they seem to be looking for things that stick out like wires cut really short or a box crammed full of wires (or a single gang duplex box with four or five NM cables going into it).
    The other thing here (may work there or not) is that when I'm not 100% sure about something I point it out and ask before the inspector discovers it -- if I did something minor wrong, he says how it should be (before the next inspection) and then signs it off.
  18. hj
    quote; 14-3 to one device box with two switched hots and then continuing on with 14-2 to another.
    That assumes the two "switched hots" have a common path.
Similar Threads: Gang Switch
Electrical Forum discussion & Blog 3 gang Insteon switch install driving me nuts~ Jan 17, 2016
Electrical Forum discussion & Blog Does ANYONE make a switch with MULTIPLE DIMMERS in 1 gang, for LEDs and 3 ways in decora/rocker?? Nov 8, 2015
Electrical Forum discussion & Blog 1 circuit/2 gang 3 way switches- Does this look right? Apr 17, 2014
Electrical Forum discussion & Blog 12/4 to run constant and switched receptacles in 2 gang boxes Apr 2, 2014
Electrical Forum discussion & Blog Cconvert 2 gang switch to 3 gang switch Jan 5, 2012
