3rd Floor Bathroom
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by R3Improvements, Sep 21, 2009.
  1. R3Improvements
    R3Improvements DIY Junior Member
    Sep 20, 2009
    Toledo, Ohio
    I'm remodeling my 3rd floor bathroom. In order to maximize my bathroom, I would like to put a 90 degree elbow in my existing 4" cast iron plumbing stack (it currently runs straight through the middle of the bathroom and exits the roof immediately above the bathroom), run about 3 feet of horizontal pvc at a 1/4" pitch, and then put another 90 degree elbow in and vent it through the roof.
    In the 3 foot PVC section mentioned above (horizontal PVC with 1/4" pitch) I would like to tie in the toilet drain pipe. I could vent the toilet as well.
    Is this against code?
    I apologize, I posted a similar question yesterday, but I'm not sure I was clear in what I was trying to do.
  2. seaofnames
    seaofnames DIY Senior Member
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Dont use the vent from the lower floors to act as a drain for the toilet, or anything for that matter.
  4. R3Improvements
    Sep 20, 2009
    Toledo, Ohio
    THe house only has one vertical Waste and Vent Stack. This is the stack/Vent I'm proposing putting the 90 degree elbow in. Is this still a problem?
    Thanks for your quick response and help.
  5. seaofnames
    Jan 25, 2009
    Boilermaker
    Mission, BC
    Check code in your area for requirements of how many fixtures you can drain into one stack.
  6. R3Improvements
    Sep 20, 2009
    Toledo, Ohio
    Good advice on checking with local code. If they say it's okay to have 3 baths going into one stack, do you think its okay to do what I origally proposed above?
    THanks for all your help. THis website is pretty amazing.
  7. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    That configuration is pretty common here, in older buildings.
    I'm pretty sure the answer is "no". The whole thing has to be straight up & down, no offsets or elbows of any kind, for it to work properly.
    If you think about it for a couple minutes, I'm sure you can see why...? :eek:
  8. jdgoodman
    jdgoodman Journeyman Plumber
    Sep 14, 2009
    Seattle
    You can not drain a fixture on one floor into the vent of another fixture on the floor below. The toilet on the bottom level is most likley re-vented but the one on the main level is not. I have seen what you want to do done in many homes and it works fine but it is not to code.
Similar Threads: Floor Bathroom
Plumbing Forum, Professional & DIY Advice Second floor bathroom group with a horizontal Wye Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Basement above floor Bathroom Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Help with lowering 8" raised bathroom floors Sep 4, 2016
Plumbing Forum, Professional & DIY Advice installing a bathroom in second floor garage Jun 16, 2016
Plumbing Forum, Professional & DIY Advice Second floor bathroom in cottage Sep 6, 2015
