2nd meter
Discussion in 'Irrigation / Sprinkler Forum' started by v1rtu0s1ty, May 31, 2007.
  1. v1rtu0s1ty
    v1rtu0s1ty DIY Senior Member
    Sep 18, 2006
    Chicago IL
    I'm getting a second meter. I will use this for my future irrigation system. However, what should I tell the installer so that I will have a really good pressure? I remember, he told me that I need 1" meter. However, I don't know what he was talking about.
    Any help would be greatly appreciated.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You need to get a handle on the difference between pressure and volume. Your pressure will not change with the meter sizing, that is determined by the pressure in the city's water main. The volume that can be delivered at that pressure however, will be greater with the larger size.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Remember that your base water charge will vary with meter size. Ask the city what the monthly base fee is for a 5/8, 3/4 and 1". Get your sprinkler system designed to use the smallest one which will be adequate, as you will pay dearly for the larger meter
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    It might be worthwhile to investigate just using 1 larger meter for both your domestic and irrigation. This would require a backflow preventer to avoid the possibility of cross contamination. The one factor that seems to vary by cities is how the sewage charges are handled. For example, my city takes the water usage in the dead of winter as a base rate and does not charge sewage use on the added water usage in the summer. My backflow preventer has to be certified annually, and I use a 1" meter.
  6. dowop
    dowop New Member
    May 19, 2005
    The size of the meter is the size of the pipe on the input side of the meter and therefore directly attributed to the volume of water that can pass to the irrigation zones. There are way too many details to look at in determining the meter size with an irrigation system because without knowing your contractors plan for heads, zones it is a crap shot. I'm assuming that since he told you to get a 1", that he is planning on building the plan with that GPM in mind. By you just using a smaller meter, you WILL have to re-work your plan.
    What ever you do.. check for credits against your sewer for having the second meter if you have public water/sewer. Around here in NJ - you would be a fool to not have a second meter. Those of us with second meters usually get a big enough credit on our sewer bill to pay our sewer bill for the winter months. Let's face it... you're going to use the water anyway, why pay the sewer bill on water you are dumping on the lawn.
  7. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    I bought an Orbit pressure gauge checker last year. I still remember the reading and it is 57psi. I just hooked it outside the faucet. Is that accurate/reliable data?
  8. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    I just finished speaking with the village and I asked them what you told to me. They told me that there is no monthly base fee. We are just going to pay for the water usage.
  9. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    Yes, this will be dedicated for irrigation. It won't be used inside the house maybe for washing the cars. I have confirmed from the village that water usage for the 2nd meter will not be used for calculating the sewer bill.
  10. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    I will be installing the irrigation system myself. Only the second meter will be done professionally.
    Yep, confirmed, sewer bill won't be calculated against the 2nd meter.
  11. jimbo
    jimbo Plumber
    San Diego, CA
    Interesting that there is no base fee, but I am glad we raised the issue and now you have the definitive answer. Is there a different price to install different size meters?
  12. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    If I recall correctly, the installer told me that prices are different. However, I didn't go into specifics. So should I get a 1" meter?
    I will call them again next week so they can do free estimate.
  13. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    Ok folks, I did some investigation regarding water pressure.
    Here are 2 pics of the gauge connected to my fire sprinkler system. Reading says it is somewhere between 75 and 80 psi.
    [​IMG]
    What is the red knob for?
    [​IMG]
    I connected the orbit to the outside faucet. Is it also called hose bib? Anyways, the reading was 54 psi. I was wondering why I was missing the 3 psi. I recalled that I forgot to turn off the other outside faucet. It's currently running right now, trickle method for the soaker.
    [​IMG]
    I'm wondering why readings are different. Can someone help me please?
    EDIT after 4 minutes: Hmmm, I remember that the guy at Ace Hardware told me that I should only use a gauge rated max at 100psi. Could this be the reason why I'm getting skewed results?
  14. Gary Swart
    Sep 1, 2004
    Yakima WA
    I suspect you have a pressure regulator valve on the domestic side of your system. 75-80 psi is too high for household use, so it is probably reduced to less than 60 psi.
  15. v1rtu0s1ty
    Sep 18, 2006
    Chicago IL
    So guys, what's the verdict? What would be your recommendation with the meter size if underground sprinkler system will be installed in the future?
    Thanks for all your help.
    Ron
  16. hj
    meter
    Use whatever size the city's incoming water pipe is. At that point a larger meter will not give any benefits. You still need an approved backflow preventer, not a Home Depot cheapest on the shelf one, ahead of the irrigation system.
Similar Threads: meter
Irrigation / Sprinkler Forum 2nd sprinkler meter Mar 19, 2008
Irrigation / Sprinkler Forum fuuny pipe or larger diameter risers-does it matter Jun 18, 2007
