2510sxt settings
Vaig
Houston, TX
Hi there,
I recently had my water softener valve and resin replaced. The new valve is a 2510sxt, and the resin is 10% crosslinked, 1 cubic foot in size. I live in Houston, TX, with city water and no iron content.
My current measurements are:
  • Hardness: 14
  • BLFC: 0.5 - 1.5 lb salt per minute
  • Water Usage - 200 gallons/day
Could someone provide guidance on adjusting the settings for my new 2510sxt valve and 10% resin?
Thank you!"
Here is what I would do for a 5600SXT, and I expect the 2510SXT settings are the same or very similar.
System info (not programmed)
salt lb/cuft = 7.5 ; A choice ( efficiency vs capacity)
BLFC = 0.5 ; Brine Refill rate GPM
cubic ft resin = 1 ; ft3 resin = (nominal grains)/32,000
Compensated hardness = 15 ; including any compensation
People = 2 ; gallons affects reserve calc
Estimated gal/day = 120 ; 60 gal per person typical calc
Estimated days/regen = 12.24 ; Computed days including reserve
Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/, Single Backwash, black cam
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 23.0 ; capacity in 1000 grains
H = 15 ; Hardness-- compensate if needed
RS = rc ; rc says use gallons vs percent
RC = 120 ; Reserve capacity gallons
DO = 30 ; Day Override (28 if no iron)
RT = 2:00 ; Regen time (default 2 AM)
BW = 5 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 5 ; Rapid Rinse minutes
BF = 5 ; Brine fill minutes
FM = ____0.7 ; https://terrylove.com/forums/index.php?attachments/img_fleck5600sxt_flow-png.31592/
