clefhanger
attempting to power the humidifier solenoid
There is a dedicated 24vac terminal on the IFC labeled "hum". It has 4v when the furnace is off and miniscule millivolts when unit is on. I'm not a professional, just a hard core DYI trying to figure out why this terminal is not sending sufficient power. All other hvac components are fully functional... thermostat, AC, and furnace.
What started the troubleshooting process is that the humidifier solenoid was not working. When the humidistat was set high enough for the terminals to contact, the furnace would not turn on. So i would have to turn the humidistat all the way down in order for the furnace to turn on. I don't have any other way of powering the solenoid to test it until I can get power from the terminal on the IFC.
Thank you for your help!
Les
Les
