2" rough-in for Bathroom Sink P-Trap?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bjferri, Mar 24, 2008.
  1. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Department of the Army Civilian (DAC)
    Maryland
    I'm glad my plumber used 2" PVC for my sink waste but I sort of wished he had transitioned to 1-1/2" for the rough in. How should I transition the 2" rough-in to 1-1/2" for the P-Trap and still have a High Box P-Trap Flange that's only 1-3/4" deep cover it - that's the deepest I think they make? If I used all PVC to make connections - it sticks out from the wall approx. 3"...
    This is all exposed decorative plumbing...
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would have used a 2 X 2 X 1 1/2 sani-tee in the wall. A 2" Tee can be bushed down to 1 1/2".
  4. hj
    drain
    Do you have a fitting hub or a piece of pipe sticking out of the wall? If it is a hub/bell then you can insert a bushing into it. If it is a pipe, cut it off flush with the wall, or behind the wall if you have an internal cutter. But before you do that, call some of the better plumbing supply companies, and see if they have a 2" 'Top Cap" cleanout fitting. If so, it will glue inside the pipe with a 1 1/2" pipe thread outlet that you can screw a brass male thread Marvel connector/trap adapter/De Sanko fitting, depending on what they are called in your area. The same company will have it also.
  5. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    Sorry about this but I made a mistake. I have a 2" X 1-1/2" UPS PVC hub...so, I don't need to reduce it then. Do I buy that threaded 1-1/2" PVC fitting that gets glued into the hub that the p-trap goes into? Or, do you recommend something else? My motto is do it once, I don’t care the cost, so long as I don’t have to do it again. Thanks…
  6. jadnashua
    I think you could just glue in a Desanko fitting that would let you connect the drain line directly using it's compression fitting.
  7. hj
    fitting
    You get a street/spigot trap adapter, that glues into the hub and has a slip joint for the trap on the other end.
  8. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    Thanks...off to Lowes or Home Depot.
  9. hj
    adapter
    good luck finding what you need there.
Similar Threads: rough-in Bathroom
Plumbing Forum, Professional & DIY Advice Need bathroom rough-in guidance: branch squeezed b/w WC and soil stack Sep 21, 2016
Plumbing Forum, Professional & DIY Advice Installing rough-in's for future bathroom during whole house re-pipe Oct 15, 2015
Plumbing Forum, Professional & DIY Advice Need Basement bathroom Rough-In advice. Pics included. Dec 31, 2014
Plumbing Forum, Professional & DIY Advice Another Bathroom Rough-In Question Nov 26, 2014
Plumbing Forum, Professional & DIY Advice Laying out Rough-in for new Bathroom in Slab May 10, 2013
