1927 Toilet....HELP!
Discussion in 'Toilet Forum discussions' started by louiesmom215, Jul 4, 2009.
  1. louiesmom215
    louiesmom215 New Member
    Jul 4, 2009
    We are refurbishing an old family home and would love to retain the fixtures. However, one of the original toilets is leaking. There is another identical toilet that is okay. However, we are planning ahead for the very real possibility that the second toilet will malfunction. The problem is the "neck" that connects the bowl to the water tank. Any ideas on where to get parts for this toilet or, (worse case scenario) a toilet like this one? Trying to attach a picture.....
      File size:
      6.9 KB
      391
      File size:
      4.4 KB
      378
      File size:
      4.9 KB
      382
      File size:
      3.6 KB
      374
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    First thing you should do is check with you local building inspector and see if either of these old monster will pass inspection. There are some conditions that will allow old water hogs like this to be retained, but usually on renovations you must go with low flow designs. This old beasts likely use 7 gallons of water per flush and are really beyond consideration for keeping. I would suggest you look at the Toto line and select one that will meet modern code and last for many years with minimum repairs. Sorry to rain on your parade, but I really can see no sense in even attempting repairs on these things.
  4. hj
    flush ppipe
    That offset flush pipe was typically American Standard. The 2134 Yorkville used it, if they still supply that model.
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    hope it never leaks...
    I recently patched ---- repaired one something like this in a home that was up for sale......
    the best thing you can do is never---ever touch the unit
    if you ever have to re-set the toilet ...then you are done....
    If it ever leaks at the spud going go buy about 4 plumbers epoxy tubes made by Hercules....at about 6 bucks a tube
    you mix them all up and then paste them around both spuds... the more the better... It is water soluable so you can form it like a clay seal effect that should
    last for decades...
    I have gotten away with murder
    many times this way.....
