120V walkway lights linstallation
Discussion in 'Electrical Forum discussion & Blog' started by drick, May 31, 2009.
  1. drick
    drick In the Trades
    May 16, 2008
    I have a half dozen 120V 3 tier pagoda lights I'd like to install along a new walkway what I am building. I guess the question to you is how would you do this? I could run 1/2 inch SCH 40 between buried bell boxes and mount the light on top of a relatively short pipe nipple off of the bell boxes, but those bell boxes aren't going to be water tight and under the ground and I think that would be a problem. Maybe it doesn't matter if I run THWN and use silicon filled wire nuts. I could cement over the entire bell box. That would make it water tight, but it would be a PITA to replace a broken light.
    Or should I just forget that whole mess and go with UF wire, silicon filled wire nuts and perma posts http://www.berkeysupply.com/product-714.html ? I initially thought this didn't meet code, but now I'm not so sure.
    Or something else maybe?
    -rick
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    The boxes cannot be buried or below grade at all. Also, the PVC alone cannot support the boxes.
    This is what I would do. I am partial to Arlington's Garden Post. They have a provision for a receptacle if you want. That or the box can be blanked off. Either way the splice is accessible without removing the fixture.
  4. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    In the olden days I would:
    Cut pieces of 2" PVC/ABS as short/long/high/low as you'd like.
    Notch the 2" stubs to clear the PVC 90's and cement/mortar them in place.
    Drill a 1/2" hole in a 2" cap and mount the fixture with a short/close nipple.
    Now they make Rocket Posts/ Perma Posts.
    I have also installed PVC jboxes in the ground, slightly above grade and installed the fixtures on nipples into the appropriate jbox cover. This method leaves the fixture/hardware very vulnerable to damage in most applications.
  5. drick
    drick In the Trades
    May 16, 2008
    Thank you for the replies. I had not seen the Garden Posts before. They are much nicer looking than a jbox above ground. Anyway I'll either go with those or the Perma Posts.
    -rick
Similar Threads: 120V walkway
Electrical Forum discussion & Blog 120V outlet in line to 240V heater? Mar 13, 2016
Electrical Forum discussion & Blog 120v w 19 gallon water heater run on 2 pole 230v breaker. is it safe? Jul 9, 2015
Electrical Forum discussion & Blog Kohler K-1174-GCW whirlpool tub provides contradictory info re: 120V vs 220V Dec 1, 2013
Electrical Forum discussion & Blog Three phase 208Y with 120V Nov 7, 2012
Electrical Forum discussion & Blog running cat6s inside plastic conduit with 120v Feb 19, 2011
