brokenblinker
We live in San Jose, CA and bought a house with a water softener. A bit over a year ago, the water softener drain was leaking, and to ignore the issue for a while (I had brain surgery, life was hard), we just opened the softener bypass and closed the route through the softener. Since then, the really hard water where we live (I've read 21grain/361ppm) has slowly wreaked havoc on all of our fixtures. Today I'd had enough, and so after getting our drain issue fixed, I turned back on the softener.
Here's where I think I messed up - I just turned the unit back on, rerouted the house water through the filter, ran its manual "recharge" process and ran some water through the house. I thought about it and realized I should check if there's any special actions we should take and found this post: https://terrylove.com/forums/index.php?threads/restarting-water-softener.105994/# which suggested putting some chlorine into the brine tank before turning the water on (oops). So now I have two questions:
* How much did I screw up by opening water supply to the house and running water through the various faucets? Is family at risk? We have a sink filter on the drinking water for what its worth.
* Knowing that I already missed this step, is there anything special I should do?
I'm not familiar with how to access a brine tank on my unit, so hoping I don't need to....I don't really have much (any?) plumbing experience in the past -> unless you count fixing yard irrigation lines haha.
