berkeley
- Messages
- 8
- Reaction score
- 0
- Points
- 0
I hope there are experts and experienced well owners out there that can help us...
BACKGROUND:
We recently purchased a vacation home in Berkeley Springs, WV. The house and well are only two years old. The house had renters, for its first two years, and they had some sort of filtration system that they took with them when they vacated the house. We had the water tested and it’s considered potable. The problem’s we have encountered, so far, are as follows:
PROBLEMS:
The well is 100ft deep and does not have a screen installed.
We have had a 30-Micron spindown filter and a 5-Micron cartridge filter installed, which does very little to reduce the cloudy water. The 30-Micron filter has completely clogged when the well is used for the first time between visits (2-3 weeks max) after which the water remains cloudy.
I am going to install a pre-storage tank Micronizer air injector and a post-storage tank Greensand-Plus filter this coming weekend. This should address the sulfur problem.
What can I do regarding the cloudy water and pump cut-off issues.
Steve
BACKGROUND:
PROBLEMS:
- The water is cloudy and was diagnosed as having colloidal clay by a water testing company. When we put a pot of the water on the hot wood stove, the clay coagulates at the bottom of the pot in globs.
- Pressure switch failure, replaced (maybe not, see pump problem further down).
- Sulfur in the water, causing the hot water to smell of rotten eggs.
- While trying to run the cloudy water out the pump just stops pumping. This can happen in less then an hour with a garden hose hooked to the outside faucet. It can take an hour or more for the pump to start back up again.
Steve
